Truck cutting out
Truck cutting out
2001 Dodge 3500 Edge 100hp injectors, edge comp box , smarty, BD turbo,4" exhaust, Dr. Evil Tranny, Afe stage 2 intake,FASS 2, tripple lock torque converter, and a full range of gauges. I've put all this stuff in now when I really get on the pedal it fells like the Torque converter is locking up and realeasing rapidly enough to make the truck shutter. I guess another way to describe it would be as if it were you had a vehicle that was running out of gas but you stayed in the throttle. I know there is fuel pressure because it has never dropped below 13 lbs. Just looking for ideas. Somebody told me it could be a computer issue will re- installing factory settings then putting the smarty and edge back on ??? Any Suggestion would be great
I have a manual torque converter lockup switch on my truck. If I forget and leave it on and start slowing down as if coming into a red light, it will do what you are saying because its locked up of course. Can you control lockup via controller or switch with your trans?
Nope I haven't installed a manual lock up switch yet the truck only does it at about half throttle around 35-45. Do you have instuction for how the wiring goes for a manual lock switch cause I'd love to do that as well
vess33
09-19-2006 09:55 PM
