Trubo Choice With Mach 1.5 Or Mach 2 For Towing
I'M LOOKING INTO BUYING TRUBO. I LIKE TO KNOW THE DIFFERINCE BETWEEN A PDR HYBIRD 35 AND A DODGEZILLA. AND WILL THEY FLOW ENOUGH AIR FOR MACH 1.5 OR MACH 2 AND KEEP THE EGT IN CHECK FOR TOWING ABOUT 10'000 LB 5VER WITCH ONE WOULD DO THE BEST? ARE THERE ANYONE RUNNING THIS SET UP . AND IF THEY ARE WHAT KIND HP ARE YOU GETTING. AND A COMP TOO. THANKS
The mach 1.5's are small enough to run on a stock turbo, unlike the mach 2's which will cause high egts. The reason I know this is because I wanted to run mach 2's, but Rod steered me right and told me to go with mach 1.5's for with my stock turbo. Now all I need is a Con OFE....
hottapper1
11-06-2007 04:31 PM
