troubleshoot my Edge Comp/MAP sensor
Guest
Posts: n/a
I hooked up my Edge Comp today, but doesn't seem to work right.
Double checked all connections, and the only thing I may have done wrong is the wrong pump wire, but positive I'm on the right one.
I've got zero power, and check engine light. Code is a P0237, low MAP sensor voltage.
Disconnected MAP sensor plugs, and re-wired back to stock harness, and all is well again.(back to stock power)
The box itself lights up the way it's supposed too, and buttons operate the way they're supposed too.
Voltage at MAP sensor plug is 5 volts.
Anyone have any ideas???Bad harness maybe???
![Confused](https://www.dieseltruckresource.com/forums/images/smilies/confused.gif)
lvmknsmoke..
08-13-2009 10:59 PM
CumminsRedneck
18
03-04-2008 07:40 AM
mx684
13
07-24-2007 07:52 PM
JD farmboy
05-21-2006 01:04 PM
rockjeep73
03-25-2005 03:34 AM
