Tried a Smarty still undecided.
I finally got my transmission done and back in my truck with a triple disk converter. What a difference. I guess you really don't notice how much power your losing through a worn out slush box lol.
So I hook up a friends smarty he let me try it for a week. It fuels hard and truck goes great but when on anything higher than sw5 I notice the fueling doesn't seem consistent and smooth. and it seems to fuel really hard just as i let off the throttle.
So with that said im not sure im ready to throw down the 650 for a smarty with no monitor or go with a edge or quad with a monitor. I don't have gauges but I do have a fp light and fass ddrp.
the truck has a blue chip special x vp44 on it.
So what are the pros and cons from people that have tried the quad adrenaline and the edge would you buy again or go with something else. just tryimng to make a informed purchase.
Tia. Garrett
Tia. Garrett
FWIW - I had the edge comp (never tapped pump) for several years and about 70% of the time it worked pretty good, tended to throw codes, intermitent power problems at the box, Edge was always good about fixing but still was not 100%. Decided to go the Smarty route, once you have performed the download to the desired level it is great! And alot more flexibility on power settings. I do wish program changes could be performed with out stopping and resetting but I have learned to live with it. I also like the ability to read more of the codes if needed. Of my experience with only these 2 boxes I would do the Smarty again if need be. Good Luck
ozob nospej
44
12-02-2007 08:13 PM
Roger_H
04-25-2007 09:01 PM
rockittboy
21
12-05-2005 04:32 PM
