Trans Temp sensor in '92
Is there a way to put a trans temp sensor in my '92 without cutting a line and splicing a "T" in? I just replaced the trans and want to make it doesn't get too hot again
'92 3/4 ton, CTD, 4x4, 115kmi auto
I've had one in the side of the pan for years & drove to keep it cool.
I'm in the process of adding another cooler, so I'll put the sensor in a tee at the front of that cooler.
DBF
DBF
I believe that there is a stock temp sensor, I don't know exactly where it is, but you can take this sensor out put in a tee then put your sensor in and the stock one back in. should take very little plumbing to get it all together.
Richpwb
08-15-2008 08:01 PM
