Tranny Problem
Old 09-22-2009 | 06:08 PM
tctblades's Avatar
Tranny Problem
Ok i think my tranny is going but im not sure. i will be driving and then it will shift into OD around 45mph and when i go to give it some fuel it acts like it wants to shift out then it doesn't and keeps doing it. Today it also does it doing 30mph and from 45-55mph. When it does this the rpms jump a little bit so any suggestions or comments greatly apreciated
Old 09-23-2009 | 01:49 AM
jnicewan's Avatar
search the forums, look at the sticky for "common problems" not guessing what your problem is but i would first look at your tp sensor
Old 09-23-2009 | 01:56 AM
jnicewan's Avatar
oh, didnt notice your a 24v but in the 12v section there is a sticky about common problems and a couple of them about the tp problems. anyway the tp sensor is kind of notorius for conditions like you mentioned and the 24v is basically the same as far as the tranny goes.
Old 09-23-2009 | 04:45 AM
tctblades's Avatar
ok ill have to check that out
Old 09-23-2009 | 08:43 AM
yfz450guy's Avatar
sounds like the t/c locking and unlocking. the o/d shouldn't come on til after 40mph if i am right. mine does this also and there have been others before us. most have traced it back to a ground issue. i would suggest cleaning batt terms and any and all grounds you can find on the truck. if that don't work there is a mod to run a new wire to the pcm on the firewall from the tps i think. these are the things i will try if replacing my batteries don't fix it. just need to make them last to the middle of next month.
Old 09-23-2009 | 10:43 AM
scottsjeeprolet's Avatar
Sounds like the TC is slipping.
Have you done any mods to the trans? I put a VB & TC in mine and it works great.
Old 09-23-2009 | 12:06 PM
tctblades's Avatar
no no mods to the trans? Dumb question whats a vb and if i get a tc and vb how much am i looking at $ wise
Old 09-23-2009 | 12:33 PM
Valve Body, Torque Converter.
Depends which brand you go with. Goerends, DTT, Suncoast, Garmon, HTS, there are lots of different brands to choose from. All depends on how much you wanna spend.
I went cheap and have no regrets. Once you figure out what you wanna go with we can put in the parts @ the Cave.
Old 09-23-2009 | 02:32 PM
tctblades's Avatar
ok cool thanks for all the input and ill let you no when i get all the parts so we can put them on thanks again
Old 09-25-2009 | 11:01 PM
tctblades's Avatar
well just to be on the safe side i got a buddy to check out my problem and it ends up being the tranny so time to get this upgrade out of the way.
Black Dog
12-03-2009 09:18 PM
high bid
08-02-2007 07:08 PM
ezdemon72
14
07-29-2005 11:05 AM
mikie1234
12-25-2004 01:54 AM
silverram323
24
11-09-2003 08:48 PM
