Tranny Cooler Line
Old 10-24-2008 | 02:00 PM
Dinner's Avatar
Tranny Cooler Line
Hey everyone,
I went to remove my hot line from the tranny to the cooler in order to install my T fitting for my gauge. The fitting that threads into the tranny was seized, so I ended up breaking that line in order to get the fitting out. My question is, should I look into getting another stock line and fittings, cut the line and install my T block. Or could I get away with using rubber hose and installing a Fitting that way? I know of one website that has the new line and T already on it, however they do not ship to Canada
Thanks!
Old 10-24-2008 | 03:15 PM
R.O.D.P.99's Avatar
With the pressure you're gonna run at, a rubber line is gonna bust.
Old 10-24-2008 | 03:19 PM
2500Ram's Avatar
I have the stock line sitting in my garage 47re. You figure shipping from Colorado and it's yours.
LMN
Old 10-24-2008 | 03:49 PM
Mike D's Avatar
Take a look at Parker hose. I'm using in my truck when I moved the heat exchanger and it's held up great.
Old 10-24-2008 | 06:48 PM
Dinner's Avatar
Thanks 2500Ram! I will try to calculate shipping and see what it would be. The only thing is the shape of the line is quite large. I will look around some more (as well as look at Parker Hose thanks to Mike D) and see if I can find anything around here in Ontario.
Do you guys have a general idea of what temperature and what pressure that line is seeing (have a Goerend HP Valve Body)?
Thanks guys.
Old 10-24-2008 | 06:54 PM
Mike D's Avatar
Your Goerend VB will push in the neighborhood of about 160-190 psi at wide open depending on how Dave set it up. Temps should never go above 270* unless something is horribly wrong in which case lines will be the least of your worries.
Old 10-24-2008 | 07:11 PM
2500Ram's Avatar
let's see if this works or still needs approved (never uploaded a pic on this site).
let me know, perfect condition just dirty. I replaced it with one from a vendor with the sender built in. Approx 78,000 miles if that matters
Old 10-24-2008 | 07:35 PM
Mike D's Avatar
Nice offer, 2500Ram! I would use it.
Old 10-24-2008 | 09:20 PM
scottsjeeprolet's Avatar
Mine did the same thing. I just installed a 1/2"NPT x 1/2" compression fitting. then some 1/2" SS tube to the T. then the stock steel line to the trans. Works fine for over 2 years.
Old 10-25-2008 | 09:14 AM
CTD2001's Avatar
just a question here, not to steal your thread or anything, but where the stock line attaches to the tranny cooler, isnt there already a short piece of rubber hose or something similar to that that hangs down off the tranny cooler that the stock complete metal line attaches to? I ask because it looks like there is a small piece of line that is flexable that hangs off the tranny cooler so you can have some movement when putting on the complete metal tranny line. I am putting a new line on my 96 that has a T in it for the tranny temp sender and when i went to install it, that previouse owner had replace all the stock metal lines with hydraulic hose and the new tranny line that i got was to short because the small piece with the flexable hose on it was gone. Maybe i am wrong but thought i would ask, thanks
Ok, i just went outside and looked at my 01 that has the tranny temp port in the hot line and it looks like there is no small piece of rubber hose hanging down off the tranny cooler. How ever when i looked at my friends 97 there appeared to be a small piece hanging down off the tranny cooler that the metal line attached to. Maybe there is a difference between the different years. Here is an attached picture of what i was talking about, thanks
Tank_66
01-11-2012 11:12 AM
isb07
11-18-2009 06:12 PM
trailxj
07-25-2005 09:00 PM
YinYaker
06-01-2004 08:37 AM
planejane
07-04-2003 08:40 AM
