Trac bar?????????????
Old 07-07-2007 | 05:55 PM
97' CTD's Avatar
Will my stock trac bar work with 2" leveling spacers?
Brandon
Old 07-07-2007 | 06:25 PM
Jordan5687's Avatar
I'm wondering the same thing. Anyone? Where to get a good one, and what cost?
Old 07-07-2007 | 06:33 PM
TB1's Avatar
TB1
The stock track bar will work with a leveling kit just did mine a couple months ago. The only thing is the front diff will shift to the driver side of the truck by about 3/4" but I can live with that until I get an adjustable bar.
Old 07-07-2007 | 06:38 PM
24V-DSL's Avatar
Call Rip for either adjustable or non-adjustablew Solid Steel T.B.
www.sourceautomotive.biz
Old 07-07-2007 | 07:24 PM
RowJ's Avatar
My Stock track bar has been on with 2" lift for a lot of miles! Shift on the frame has no noticable side effects or differences when driving.
RJ
Old 07-07-2007 | 07:37 PM
97' CTD's Avatar
Thank you all for helpin me out! Adj. will come in due time, the stocker will rock for now !!!!!!!!!!
Brandon
Old 07-07-2007 | 08:23 PM
97' CTD's Avatar
Do I have to flip the sway bar upside down and bring the end links in from the top not the bottom?????????????
Brandon
Old 07-07-2007 | 08:30 PM
Jordan5687's Avatar
I have a question too, should I get longer links or some sort of blocks to drop the sway bar? I've seen and heard about it, if so what will be different?
Old 07-07-2007 | 08:59 PM
TxDiesel007's Avatar
THUREN...
i just got theirs and it is quite a piece over the stocker... call up Dan thuren and he will hook u up.. You will not be dissapointed....
Rick
Old 07-07-2007 | 09:43 PM
rbattle's Avatar
Originally Posted by TxDiesel007
THUREN...
Rick
This.
I just installed Don Thuren's 3rd Gen bar and a conversion bracket from Piers, and it rocks your face off. All I need is a new steering column (intermediate column) and it will drive a like a Porsche with big ridiculous tires on it. Be sure, while you are down there, that the tie rod end and ball joints are still good. Replace anything with visual play in it with Moog parts or get a crossover steering kit for the ultimate fix. The steering gear box is also suspect so check it as well. Do you have a DSS?
R
see: http://www.thurenfabrication.com
Old 07-09-2007 | 12:07 PM
Beast2B's Avatar
I just ordered the 5" track bar kit and crossover steering from Don Thuren. It will be a couple weeks, but I am REAL anxious to see the difference. If you have to replace the track bar in any suspension config (stock/level kit/lift kit) get a conversion kit for the 3rd gen bar, adjustable if necessary.
Old 07-09-2007 | 12:14 PM
513yj's Avatar
i've installed many a tj lift. the front end looks exactly the same as a tj but with a 60 instead of a 30. rubicon express says to drill the track bar hole at the axle 3/4 of an inch towards the driver side to keep the axle centered. this is for 3.5" lifts tho so maybe it wouldn't work for you but it's an option. also they sell drop kits for the frame side also. not sure if there is any for a dodge tho.
89dieselkong
02-12-2011 11:06 PM
engcogod
07-06-2003 11:23 PM
powerwagon440
02-02-2003 08:34 PM
perk
02-01-2003 05:01 PM
