TPS shot
TPS shot
Found out that my TPS is shot, according to check engine code. Can anyone suggest a good replacement? Thanks! DTR, this is a great website, has definitely helped me out with my new truck that has turned into a nightmare!
tps know as your apps. check into timbo's apps. around 160 for his. a oem apps replacements go for 3-450. check with this site on the DTR store link. if they dont have I'm sure they can get it just ask them.
search ... timbo apps you will get alot of info on it
You could try this:
http://www.dnrcustoms.com/zen2/index...roducts_id=175
https://www.dieseltruckresource.com/....html?t=142641
Floyd
Floyd
you can also clean it, out of the 3 ive seen bad a cleaning is all it took to fix them.. i cut mine open and sprayed it with electrical cleaner, glued it together and its been fine since.. another buddy thought his tranny was fubar'ed, i told him to clean the TPS and his troubles went away..
you can drill a small hole and wash it out with brake clean
here is an old thread with just about everything you want to know about an APPS
http://www.cumminsforum.com/forum/98...ps-sequel.html
