towing setups...
Registered
towing setups...
ok if i put twins on my truck, what would be the best towing setup? new mach sticks? smarty of course
a tst pm3 maybe? then what can i put on it on top of that for playing-around purposes? dunno if ill go that route or not, i just need to know all the options. Thanks!
![Cool](https://www.dieseltruckresource.com/forums/images/smilies/cool.gif)
Thats what I want to do...35/14 with a HT3B or S400, mach 4's, Smarty and TST. Should be an awesome towing setup, and still be pretty quick. What twins variation do you plan to run?
Registered
i dont know if i should go with the hx-35/ht3b or hx-40/ht3b or hx-35/s400 or hx-40/s400 or b1/b2 or what. Any suggestions? id like to buy a set but id rather spend a couple extra weeks and work on it (do it myself) and save 2 grand then shell out the 4500-5000 for the kit.
![Shocked](https://www.dieseltruckresource.com/forums/images/smilies/shocked.gif)
Registered
id kinda like to run mach 6's, tst pm3, smarty, water/meth and propane with it. for the playing part of course
then the mach 6's, water/meth and the smarty for towing
![Big Grin](https://www.dieseltruckresource.com/forums/images/smilies/biggrin.gif)
Isn't a Mach 6 too big to see any advantage from a HO pump? I dont know but I thought a set of 4's was about all a Non-HRVP44 can supply?
But yeah, we are on the same page as far as the twins go, I just cant afford to pay that much for a finished kit. I am hoping to have the same combo you mentioned above with the only exception being no drugs.
Registered
well, i figure that my vp-44 will go out again sometime, then ill replace it with a hot rod pump. then she'll support mach 6's and a tst.
i want the propane injection because i can pull up to the propane tank outside the house and fill up from there
get a little better fuel milage and 50ish give-or-take hp.
i want the water meth so i can keep her really cool and another few hp
![Laughing](https://www.dieseltruckresource.com/forums/images/smilies/laughing.gif)
Originally Posted by blackdiesel02
well, i figure that my vp-44 will go out again sometime, then ill replace it with a hot rod pump. then she'll support mach 6's and a tst. ![Cool](https://www.dieseltruckresource.com/forums/images/smilies/cool.gif)
![roll](https://www.dieseltruckresource.com/forums/images/smilies/roll.gif)
I'd think the m6's would be overkill for the Ho VP44 and the hrvp. I'm waiting to see how Tiger Rag's truck performs with his new m6's.
Look at Don's comments here: https://www.dieseltruckresource.com/...d.php?t=101333
Registered
i might hit the peterbilt junkyard in springfield. get some oil lines, tubing, a mach up turbo and i can order a spankin new one or rebuild a used one. along with other misc. parts. Anything special i need to keep an eye out for?
The Guru
Boy I hate to say this, but if you tow anything with the mach 6'ers your gonna have egt's issues. I can peg the pyro pegged empty. I tried towing once, ouchy this injectors are way to hot. I would run a 130rwhp sized injector with my twins. The spool-up is slower, but the egt's are controllable. There guys out there saying you can run BD twins with their smallish 150 injectors. I don't believe it. My twins are bigger than the BD set and I'm sure that my egt's would be pegged towing anything heavy. Go figure.
Registered
humm... my injectors are 130 hp now. i kinda wanted to upgrade to mach injectors. at least 4's. which sounds like the highest i may be able to go.
Any other advice???
![Duhh](https://www.dieseltruckresource.com/forums/images/smilies/new1/duhhh.gif)
Any other advice???
i dont know if i should go with the hx-35/ht3b or hx-40/ht3b or hx-35/s400 or hx-40/s400 or b1/b2 or what. Any suggestions? id like to buy a set but id rather spend a couple extra weeks and work on it (do it myself) and save 2 grand then shell out the 4500-5000 for the kit. ![Shocked](https://www.dieseltruckresource.com/forums/images/smilies/shocked.gif)
35/3b
is the cheapest way to go and from what i understand, its very good on EGTS, good to about 60-65 lbs boost max, but very towable.. its teh setup im lookin at, if u put a 40 up top, u might be able to get 70-75 lbs of reliable boost... with water meth to cool it off, and propane, i think ull be fine with ur current injectors, and ull be way into the 500 horse range... and towable...
I know merrick cummings current dually, goes by MCummings on here is running a sweet towing setup. with a 40 on top and he is at 522/1025 or somethin like that.
Rick
![](https://www.dieseltruckresource.com/pics/data/500/35035Misc_May_3_017-med.jpg)
The Guru
Are your rear tires touching your deck? Thats a easy load for a cummins and still would be able to pass most of the empty fords (of course) on the hills. Nice trailer, I sure could put it to use.
