Towing with a HTT 1362?
Anyone doing any 10K + towing with this HTT turbo? Just wondering how the spool up is and egt control.
65mm drive wheel and 62mm extended tip compressor wheel with the 13cm Stainless Steel Alloy turbine housing.
Mine dosent tow well at altitude, its not a 13ss, rather a 12. but towing 18500 gross when the outside temps were warm, I had temp issues.....
I havent updated the post, yet, and my turbo isnt from HTT FWIW
Sounds like I might be better off with some twins. Elevation range I drive in is 4500 to 9000ft. It would be nice on the mountain passes to be at speed limit or above with manageable EGT's.
in 5th gear at 65
I believe we altitude challenged folks need higher drive pressure to do the work, my truck drives awesome, and I can use all my power, but not towing on a warm day.... its to bad.....
On a cool night I was able to hold 65 on cruse, same load 65-70*day at 65 My water temp was standing at the 3/4 mark before I took my exit. the problem I had was the egt temp at 1100* for the 3-4 mile pull
in 5th gear at 65
in 5th gear at 65
O.T
16
01-14-2008 03:47 PM
jmccart
11-25-2007 12:38 PM
Bobcat698
11-08-2006 12:20 PM
justagoodolboy
10-26-2006 09:57 PM
