Towing with a Comp?
Old 03-07-2006 | 05:23 PM
ramcummins's Avatar
Towing with a Comp?
What level and sub level do you guys run your Comps on while towing heavy loads?
Old 03-07-2006 | 05:28 PM
CTD NUT's Avatar
3x4 and 5x5.
Old 03-07-2006 | 05:30 PM
ramcummins's Avatar
Originally Posted by CTD NUT
3x4 and 5x5.
How 'bout EGT's
Old 03-07-2006 | 05:31 PM
jiMMyCTD's Avatar
im always trying different things with this comp box. the pyro was already there and it is post turbo which i am not a fan of.
i have hauled roughly 6500 lbs through the sierras at 65 mpg average barley on it on subleval 2 and power leval 2. egts never wen t byond 760.
Old 03-07-2006 | 05:39 PM
Gotlift01's Avatar
I leave mine on 3X3 all the time for everything.........works great and doesn't belch to much smoke when towing. When I had my 35" tires on and stock 3.54 gearing I could tow my buddies rock crawler in the mountains at about 65-70mph and see no more than 1000* EGT unless I got slowed down and then it climb up around danger zone until I got the boost up.
~Nick
Old 03-07-2006 | 05:58 PM
CTD NUT's Avatar
Originally Posted by ramcummins
How 'bout EGT's
EGT's are not a problem. I gross out a 19,300 lbs GCWR and only ever have to get out of 5x5 on very long and steep hills....other than that, it is 5x5. 4" exhaust and a Scotty II really help with the egt control. I only have RV275's, though.....no doubt, I would be turning the Comp down or off when towing heavy if I had bigger sticks and stuck with the HX35.
Old 03-07-2006 | 06:12 PM
ramcummins's Avatar
CTD NUT
What turbo are you running?
Old 03-07-2006 | 06:57 PM
Tiger Rag's Avatar
1x1 towing 12,000, but I'm probably a candy a$$. New turbo's on the way, I'll probably bump the box up next time. Never any egt issues at that weight on 1x1 with mach 1.5's.
Old 03-07-2006 | 07:42 PM
CTD NUT's Avatar
CTD NUT
I'm just running the stock 12cm HX35.
Old 03-07-2006 | 08:45 PM
duallydave's Avatar
i agree with gotlift,i tow my 5er,on 3/3,i have 130hp injectors and the stock turbo,anything higher and egts go over 1000,
Old 03-07-2006 | 09:58 PM
Mike Holmen's Avatar
The Guru
I ran 4X4 on my comp. It allowed me to pass faster, yes the egt's got hot but its only a couple seconds. If your towing heavy and in the mountains you might want to run 3x3. I have tried to tow anything with my current set-up but the only issue I should have is coolant temps and thick smoke clouds.
Old 03-08-2006 | 11:39 PM
Bart Timothy's Avatar
I usually tow with the Comp off for smoke reasons, especially in stop and go conditions. I also turn it off when I use the cruise control because of extreme throttle sensativity. Sometimes I'll turn it on, once up on the highway and rolling along. The added timing adds to fuel mileage. As for egts, you can always turn it on 5x5 and control them with your right foot.
MoreSmoke
01-07-2004 10:40 PM
James Lucas
14
08-29-2003 12:24 PM
hellotbone
07-12-2003 01:58 AM
hellotbone
18
05-16-2003 05:40 PM
danlit
02-13-2003 11:53 AM
Quick Reply: Towing with a Comp?
