Torque converter recommendations.
I have a 2001 2500 with 200k on the clock, 50 hp injectors, edge comp (not unlocked). Stock converter recently started slipping. Time for xmsn rebuild and upgrade tq converter, what are some good converters for a moderate power level (300 hp) at a reasonable price. I know the sky is the limit with torque converters, I just want a reliable one at a good price- thanks.
I've had very good experiences with Tim Barber from tre.
If you talk to any transmission builder be honest on what you want to use the truck for and what your plans are.
In my opinion the TC clutch is really well sorted by the reputable aftermarket companies, but the selection of the correct hydraulic characteristics to fit your application is the most overlooked factor in this industry- leading to driveability issues that aren't necessary.
2smoke4ever (11-06-2018)
Try to find a loan rebuilder that isn't connected to a chain that has a good "word-of-mouth" reputation. They are the ones that will "build-to-order" and not to a spec sheet supplied with pre packaged parts kits.
93dieselZak
06-16-2011 07:10 PM
PCline
24
06-01-2007 09:07 AM
HydraulicGuy
05-09-2005 12:13 PM
