torque converter
Old 06-13-2007 | 06:29 PM
scoutdog's Avatar
Question torque converter
I'am new and need help.I own a 01 Dodge 2500 diesel and pull a 10000# horse trailer.I had a new valve body and temp.gauges.One was for trans. and the other for the torque converter.Here is the problem I'am having. When in traffic a lot of stop and go the torque converter temp. will climb to 220 degrees. Is this a problem to be concerned with if so any suggestions.
I also would like to install a chip to pull with. I need help.
Old 06-13-2007 | 06:54 PM
HOHN's Avatar
The stock tc on these trucks is loose and generates a lot of heat. Pulling 10K regularly will definitely tax everything to the limits.
Ideally, you could get a replacement tc. The aftermarket units are much better.
In lieu of that, just install as much cooling for the trans as you can. A Tru Cool H7b is a great cooler, and going to a deeper tranny pan can also help a bit. PML and Mag-hytec make really good pans.
Try Geno's garage for the pans if the DTR store doesn't have them.
Justin
Old 06-13-2007 | 07:31 PM
paulb's Avatar
220 is getting border line, and a tight aftermarket converter will only make it go higher in stop and go traffic. One thing you can do is to put the tranny in neutral everytime you come to a stop. And like Hohn said, put an external cooler with a fan on it.
I know it's not the same thing, but in my truck if the fluid ever reaches 240 degrees, I change the fluid when I get home after the race.
Sorry can't help with the towing chip... I'm sure somebody that tows heavy will chime in...
Paul
Old 06-13-2007 | 07:48 PM
JPR Ram's Avatar
From: My head lays down in Murrieta, but the day light hours are spent in San Diego, Ca.
A chip for towing? I'd start by looking at Quadzilla and Edge. Both make excellent mild performance/towing chips....
lniemeyer2
10-24-2012 01:11 PM
93dieselZak
06-16-2011 07:10 PM
mainer
07-17-2007 08:13 PM
