top boost for stock 99
Old 04-22-2006 | 09:24 PM
trex's Avatar
whats the highest boost i can expect from a stock 99 24 valve?
Old 04-22-2006 | 09:49 PM
inline6power's Avatar
well i have a 99 and when it was bone stock, and i mean bone stock, i would top out at 22 to 23. the first mod i put on was a VA box and a boost elbow and the boost then jumped up to 33 to 34. but typcally a stocker should run between 19 to 23
Old 04-25-2006 | 06:10 PM
trex's Avatar
huh, i just hooked up my boost gauge and it maxs out at 18. i also have a dr. perf. stage III hooked up to the map sensor.
Old 04-25-2006 | 06:30 PM
natlchamp2k4's Avatar
To get more boost you must either put in a boost elbow(blocks the wastegate), use a manual boost controler(allows you to set the max boost you want, usually 35#'s for a stock HX35), or use the cheap turnbuckle method ( use a 6-8" turnbuckle and use it to hold the wastegate shut.
When a box is hooked up the MAP sensor this only fools the computer into seeing 20#'s of boost, in effect keeping it from defueling. When you are actually seeing more than 20#'s, the truck will still be fueling.
These have to be used together with each other or like in your case you will only see 20-22#'s or an overboost code if you block the wastegate withouta boost fooling box.
Old 04-25-2006 | 09:23 PM
newriverSpecon's Avatar
Mine would give me 18# normally. If I really stayed on it 19. With the injectors only I could get 23. + VA 25. Plugged the WG line and I see 34-35 max and settle to 33-34.
Randy
Old 04-27-2006 | 06:45 PM
trex's Avatar
which direction would be the best way to go to control the wastegate? who sells what i need?
Old 04-27-2006 | 10:07 PM
I just put a plug in the W/G sense line. I don't want any high pressure anyway so I haven't mechanically held the gate closed. a 1/4" bolt and a small hose clamp work fine. If you don't clamp it the line swells and allows the gate to open.
Randy
Old 04-27-2006 | 10:17 PM
smokindog's Avatar
Just click here and you can see what everyone is talking about. It's not the cheapest route, but it is the one I have on my HX35.
vwjunkie53
19
11-09-2007 03:27 PM
CTD NUT
Off Road / 4x4
10-20-2007 02:57 PM
Bobcat698
18
10-22-2005 01:27 PM
