Tools Needed for Headstud install
On 3rd gen bottom tapping is advised as well. If I would have bottom tapped to begin with I wouldnt have had to grind my rocker housing down at all ( )
supposedly ARP came out w/ a new PN that is a little shorter and doesn't require grinding the valve covers, but I'd rather have full thread engagement and not have to mill rocker stands to get it!!! if you bottom tap, it doesn't take but 10min of grinding for all 6 covers
hey guys i didn't see what studs you all were talking about, is it the 12mm or 14mm head studs, i heard that there is more work involved on the 14mm but never heard of tapping with the 12mm, please fill me in on whats what, thanks
65fury,
The 12mm's can be installed without bottom tapping.
On our engines/blocks there is more hole than there is thread if you know what I mean. And 100% of the time all of the holes threads are not at the same depth.
So that is the reason we bottom tap. Not only does it insure maximum thread engagement for the stud but it also looks good and right!
14mm are a whole different subject. When installing 14mm's you have to re-drill the block to a larger size and re-tap each hole to 14mm. There is also head work involved so it will accept a larger stud.
65fury,
jr22
05-22-2007 11:49 PM
Rpainter
03-07-2007 04:35 PM
acook
08-29-2006 10:08 PM
