Too much smoke with Smarty?
I'm thinking about getting a Smarty and with all the hoopla surrounding them it's easy to get swept up in the frenzy! But what I really am concerned about is unwanted smoke. WIth my Comp and DD-3's I can either roll the smoke on call with box on 5x5, or turn it down and drive around smoke free. With the heavy low end fueling of the Smarty it seems as though it's going to be hard to not smoke off idle. That to me would get old real quick. Is it possible to control the smoke when running a Smarty? I'd like to hear from some of you users that have bigger aftermarket injectors and a Smarty.
I have no off idle smoke. I can drive my truck completely smoke free. With that said, the higher levels on the smarty do make it difficult to roll into the throttle without leaving a cloud behind. Even with the lower levels going to 1/2 throttle will blow a cloud out if I don't roll into it. Day #1 testing with sw3 did still leave a few unintended clouds behind, but I'm running sw1 fuel saver right now to help save my clutch and I'm almost completely smoke free except for a few intentional clouds =P
You will learn to drive differently with the Smarty/catcher. You need to drive it easier too. It will deliver the fuel quicker, but you have learned that you need to push the throttle quite a bit to go when stock timing is used, that is cured with the Smarty.
Of course, it will smoke more if you stab the throttle.
There are plenty of settings on the Smarty to keep smoke down. On fuel saver mode, I could not smoke at all. On the lower Catcher settings I can lay a big cloud if I have to gun it fast. I have never tried the 1/2 power lowest setting, but Marco says it will not smoke at all. Smarty will control smoke as good as a Comp.
I have DD3's and my truck is Smartified(SW#9). Smoke is controlled by the position and application of the go fast pedal. When mashing the pedal the coal certainly rolls but the truck can be driven smoke free after learning how to drive with the new found low end fueling.
If I'm going to have to "walk on eggshells" so to speak when I leave every stop sign, I'm not sure I'll enjoy it very much. The whole point of me getting a Smarty was to help with the awful torque management in the lower gears. But if smoke is a trade off then I might as well just crank up the comp to 5 to get better low end and live with clouds of smoke. Does this make sense?
Nope!
Turning the Comp off around town and using the Smarty timing to ad in smoke control makes better sense.
This time of yr, with Smarty on #7 and Mach 4's... smoke is not an issue (with TST off or on low setting)!
No point in trying to second guess. If you have doubts...wait for one to show up in your area and try it! Otherwise... just do it! You won't be sorry.
RJ
RJ
Ever drove a 12v?? From what I understand, that's how the Smarty feels! You'll just have to re-learn how far the pedal goes before you start rolling the coal!
The 24v's (w/Comps) I have drove feel like they have switches in the pedals...my 12v is smooth and responsive to how far you push the pedal! You can even put out the fire if you roll in too far...and black out intersections
I'd say you really need to feel a Smarty...but that would make me a hypocrit
Chris
Chris
If you don't mat the go pedal at every light you should have absolutely no problem with the Smarty. I can take off from a light fairly quickly with zero to a light haze. I don't have a fueling box so I run around on #7 90% of the time.
Steveareno
04-20-2010 11:50 PM
jjrightmire1973
11-20-2008 08:20 AM
Kevin Krieger
05-01-2007 09:52 PM
