Too high of fuel pressure?
Well everyone, just came back from my trip to the desert for a little over a year and had a bunch of things waiting for me to put in the red rocket. I put my banjo bolts on and hooked up the fuel pressure gauge. I hooked the gauge up at the input of the fuel filter. I have a carter pusher pump as well. At idle I see 23 psi and at wot I see 15psi. Is this too high? I just want to make sure that everything is where it needs to be. Thanks
I don't see a problem with 23 psi...as long as you don't have any starting problems. Some members have said that over 18 psi causes difficulty starting...not true in all cases.
RJ
RJ
tinknocker827
13
12-04-2013 06:26 PM
GlennRMK
05-24-2007 10:46 PM
cheff
01-23-2006 09:44 AM
RowJ
33
09-15-2005 07:00 PM
