tire size question for adr.
Old 09-30-2008 | 12:11 AM
quads4_life's Avatar
I am trying to set the tire size on my quadzilla adrenaline but not sure what my tire size number they are looking for?? I have 315/75/16 on my truck but I dont know what that relates to for the adr also what is stock for my truck it was a 245/75/16
Old 09-30-2008 | 05:37 PM
um anybody
Old 09-30-2008 | 05:58 PM
kawiram's Avatar
Dont have the adrenaline, but it should need the tire size you have now. 315's are anywhere from 33" to 35" tall. Id measure the back tire for a more accurate measurement.
Old 09-30-2008 | 06:24 PM
Nohel's Avatar
315/75/16 = 245/75/16 =
Diameter: 34.6 Diameter: 30.5
Section Width: 12.4 Section Width: 9.6
Section Height: 9.3 Section Height: 7.2
HEIGHT = ((width * aspect-ratio * 2) / 2550) + rim size
WIDTH = (width / 25.50 )
Old 11-29-2008 | 07:00 AM
bobke20's Avatar
same question
i just installed the adr and have the same question does any one have the answer?
Old 11-29-2008 | 10:37 AM
Crazydave's Avatar
I think, the number it wants is the tire diameter x pie so if you have a 33 inch tall tire you would take 33 x 3.14 = 103.6 and that would be the number to plug in to the adr
Old 11-29-2008 | 10:48 AM
Crazydave's Avatar
Hes a calculator for finding diameter http://www.4lo.com/calc/gearmetric.htm
Old 11-29-2008 | 01:38 PM
busta's Avatar
here is another calculator http://www.web-cars.com/math/tiresize.html
Old 11-29-2008 | 03:18 PM
RowJ's Avatar
Go to 'Hardware'.... then 'Tire Size Correction'.
The number you want will be around 106% or higher.... 105.0 works for 265's. Be sure and save it with bottom button on Pulse.
If you can get it to work (mine use to but won't anymore)... just play with the number until it's corrected!
RJ
AlanF
11-28-2010 04:00 PM
AlanF
02-14-2009 11:12 PM
quads4_life
01-15-2009 01:30 AM
quads4_life
11-10-2008 07:42 PM
dieselguy71
04-24-2008 03:09 PM
