Tire Balancing Beads
#61
mikal711
Just a quick note about using them in cars, I have found that you stand a good chance of having lateral wobble in the tires on cars when using the beads alone. I have tried the beads on two cars (one of which has 195/65-15 tires) and both of them have quite a bad vibration with the beads.
Mishkaya
Mishkaya
#62
What brand did you use?
I started running Counteract in the tires at work about three years ago and haven't run into a problem. That's 22 sedans, SUVs and light trucks with a wide range in tire sizes. It could be you didn't use enough material.
#65
If you have a bad tire the beads or weights won't help. If your tires and wheels are good they will easily balance with the beads.
I've seen several people that are having trouble with their tires shaking, try to add beads for a miracle fix, they need new tires.
#66
I will still be trying them on the Ram as soon as I get the new tires for it. However on the cars there were no vibration problems prior to installing the beads, so I am quite certain it has something to do with them. And I did break down the tires each time I added more weight, and didn't notice any problems with the beads being stuck or anything. It has me stumped.
Mishkaya
Mishkaya
#67
I just ordered DynaBeads from Inovative Balancing. According to the chart, they recommend 4 oz. per tire for my size. I ordered 5 oz. per tire just as a little margin of overkill. Does this seem to be enough?
#68
rattle_rattle,
I get a kick out of some of these names you guys come up with
Anyhow, you will be fine with 5 oz. That's what's nice about the beads. If the inside is clean, they will use and position whatever is required to get the job done, and evenly distribute the unused portion so that it has a zero balance effect.
Robert
Robert
#69
Received my Balancing beads yesterday! Looking forward to mounting my tires. Got a tire bead lubricant from NAPA. I am cleaning up and painting my rims now, hope to have the tires and balancing done by Friday! I will let everyone know how everything turns out....
Tires: Hankook DH01 Super Traction 225/70R19.5
Rims: GM step van 8 on 6.5 19.5x6.00 rims (Firestone brand! and Accuride)
Beads: Dyna Ceramics
#70
Well...
I just got done with a test drive after adding 5 oz. of DynaBeads from Innovative Balancing in each tire. It took almost three hours due to the beads jamming up trying to put them in. I removed all the lead weights. My truck shakes like crazy. Sometimes when the imbalance gets in sync and two or more tires add, it's difficult to keep it on the road. It looks like I made a mistake. Not only am I out the money I paid for this "snake oil". Now I have to go get them balanced at the tire shop again. Live and learn.
#73
RickCJ:
I had one tire that was slightly out of balance, barely detectable. So, IMHO, the tire is balanceable (is that a word?). As for having two bad tires out of four, that sounds unreasonable considering they cost $200 a piece.
zulusafari:
No. I didn't break down the tire or do any cleaning or drying.
Just as an update. Innovative Balancing is willing to give me a complete refund if I'm not happy. At least that will cover that loss.
zulusafari:
