time for a clutch,any sugestions??
hi guys,im running a comp on level 3-5 mostly and 130hp injectors,clutch fianally gave in and slipped a bit,what are some good brands to look for and what prices should i look for.i have a guy to do it for me.thanx
Not sure about prices, but LUK and Southbend are some manufacturers to consider. There are others out there as well. I'm sure someone will chime in with other names.
~Rob
~Rob
Cant go wrong with southbend
Give Peter a call, his clutches are very well respected and a have a good reputation with this group, and even the fords...
Best of luck!
Tx
Best of luck!
Tx
Registered
im runnin 130 horse injectors and a edge comp. just wnet to a south bend double disk clutch. pedal pressure is stiff and it makes a whole lotta noise but it holds reallllly good. i would do it over again.
blackdiesel02, which pressure plate and clutch did you go with? I am surprised that it takes alot of pedal effort. I had heard that the 3600 pressure plate was prettycomparable to the OFE and FE, which are both comparable to stock.
Waylan
Waylan
Big T
17
06-24-2007 11:40 PM
Vintage Empire
01-30-2007 08:36 AM
taken5875
06-08-2006 10:35 AM
