Thoughts on this Setup
Old 10-23-2008 | 04:58 PM
sammy340's Avatar
Hey Guys
Just wondering if i could get some opinions on this setup i will be installing in the next few weeks, and any problems i may come across.
The truck is a 98.5 24V 5spd, and the goodies i got for it are.......
-HTB2 62/65/12 turbo
-Mach 4 Injectors
-Smarty (not with Revo S/w)
-TST comp
-FASS 95 GPM
-4" MBRP exhaust
-SBC CON OFE
Anyone see any bottlenecks that may arise? Turbo big enough?
Any guesses on HP?
Also, whats the thoughts on the new REVO S/w for the smarty? Worth Getting?
Thanks in advance!
Jeff
Old 10-23-2008 | 06:10 PM
jerrethomas's Avatar
looks close to a 500 hp setup. Although the turbo with a 12 housing might limit you due to your egt's. Other then that should make good power and spool quick.
Old 10-24-2008 | 12:04 AM
busa's Avatar
The turbo will spool great but hurt your top-end power. I rec. the South Bend slave to go with the clutch. If you tow heavy it might get warm.
Old 10-24-2008 | 08:58 AM
can17's Avatar
My brother has almost that same setup on his 02. The only difference is he has a PS 62. His truck made 486 hp, but he has the H.O. injection pump....
Old 10-24-2008 | 10:09 PM
heykw's Avatar
go with the fass 150 pump
I would as so go with a 64/71/12 turbo
5in exaust
I would guess 500 HP
Old 10-25-2008 | 01:54 PM
HOHN's Avatar
The FASS 150 pump is wrong for the application. Your truck will burn a max of about 80 gph. Add another 10-20% for cooling and fuel dribble, and you can see that a pump 150gph is will so restricted from it's optimal design that it will only heat the fuel, aerate it, and reduce the pump life as it contantly fights more restriction than it needs to.
The only way to use this pump and let if function properly is to use a large bypass regulator that allows the pump to just circulate fuel in a loop if engine demand is low.
JMO
Old 10-25-2008 | 04:41 PM
Mike Holmen's Avatar
The Guru
You're running a mid sized HP turbo, if you want more top end go with twins or a larger turbo. The turbine housing is on the small side. A S400 under that turbo would make for a nice driver. Tuned right, you put up to low 600's with those injectors without nos or methanol.
Old 10-25-2008 | 08:11 PM
heykw's Avatar
hohn I would rather burn up a fuel pump than a vp44.
Old 10-26-2008 | 03:32 PM
sammy340's Avatar
What would you guys recommend for a larger turbo with this setup? A 64/71/14? I was hoping to be able to run the 62/65/12 for awhile before i had to upgrade...........
What kinda boost pressure's can i go up to without worrying about the HG with stock head bolts?
Old 10-26-2008 | 04:15 PM
The Guru
Don't get us wrong, it will work, just watch pyro for high egt's. If you tow, you might have to find a smaller set of sticks. Its a good starting point, I've run the fass150 for at least 4-5 yrs and got about 150000 miles on it. You wont have any issues with it. It for future down the road power upgrading.
Old 10-26-2008 | 10:12 PM
busa's Avatar
I've been running 45-47 psi for a while now on stock bolts with no issues. Make sure its warm first and don't stay at 45 psi all day and you should be fine. My 62/71 seems to work pretty good.
Old 10-26-2008 | 11:28 PM
The Guru
Sammy, a smaller turbo is only going to limit you're top end power. I probably wouldn't run the smarty /TST with that turbo. If want to make more HP go with NOS at dynodays and run the smarty. You have a nice daily driver turbo that works well on spoolin fast, just the turbine and compressor impeller is on the small side for big hp numbers. A S400 under that turbo would work very nicely. You just have to land if you want that big power level you want every time you push that throttle down hard.
Old 10-27-2008 | 02:37 PM
Ph4tty's Avatar
Understand this, going from a 62/65/12 to a 64/71/14 is upsizing three things, the housing size, the turbine size, and the compressor size. Only reason to go that big is if you wanted a competitive truck. I'd go with a bigger housing for the stick and maybe a bigger turbine if you to have a little more fun.
ryanihf250
01-17-2008 03:58 PM
kuhkuhkyle
10-19-2007 02:39 PM
Dieseldude4x4
02-24-2003 02:28 PM
FiverBob
02-14-2003 12:42 PM
cliff-1972
0
10-13-2002 05:04 PM
