For those of you who have installed a Transgo Shift Kit in the 47RE...
Does this kit look complete to you? Looks like it's missing some springs, but I'm not sure.
http://cgi.ebay.com/ebaymotors/ws/eB...9920122&rd=1,1
Or is this new, updated version worth the extra money?
http://cgi.ebay.com/ebaymotors/ws/eB...1077203&rd=1,1
The first one (TFOD-Diesel) is the one I used to have in mine. Great kit for the money. Im pretty sure it shows everything that came with mine, so I dont think its missing anything I dont have any experience with the second one though
Eric
Eric
Go for the second one. There will be less drilling which means you will not need a special set of drill bits (they ask for some odd ball sizes). It looks to me as though all the springs are there and I have put quite a few of those bad boys in...
Location: Climax, MI (between battlecreek and kalamazoo)
The first one is the advanced kit and the second is called a reprogram kit because it comes with the pre-drilled separator plate, i would recommend the first one if you can follow directions then you'll have no problems. one bit of advice for the first one if you decide to drill your separator plate ignore the hole size guide and just go big with it. And to answer the drill bit ? the bits come in the kit but they are too small for drilling the separator plate, so just have a drill bit set handy.
Do you recommend I drill it or not?
I was leaning towards the second one but now you got me thinking. I called Transgo about this, and the guy told me that the second one is the same as the first one except it's the "new version." Basically, they discontinued the first one and now only make the second one.
Anyway, it's friday night so I'm in no hurry to order. Heck, I think I'll just go with the first one. Sounds like it's basically the same thing and costs half as much. Unless anyone thinks otherwise...
Yes you can go with the second one i usually get a new separator plate anyway to start with, but you definitely want to drill it, that gets you higher and faster flow and increases shift firmness. PM me if you decide what you are gonna do and i can give you a few pointers on some things the instructions leave out. also how is the truck used?
I don't tow. I have a #10 plate and gsk. I just wanted to add the shift kit to prolong my tranny's life with the mods. Plus, I'm hoping it'll make the drivability better.
The valve body will help your trans the most possible, with a few mods to the instructions. The biggest downfall of your trans will still be the stock slushbox of a converter that the stock trans use. The shift kit and valve body mods are still the best thing for the money though.
Thanks for everyone's input!
shrmpboatcptn
11-16-2010 06:46 AM
DezertBum
04-04-2010 01:31 AM
Need95-00CTD
06-26-2007 07:48 PM
