For those running with a BHAF
Old 12-26-2004 | 03:30 PM
jrs_dodge_diesel's Avatar
Exclamation For those running with a BHAF
Be sure and check to make sure the intake hose is still clamped on. I had mine pop off this weekend. Kinda made me horrified to think the engine was suckin down unfiltered air.
Old 12-26-2004 | 03:41 PM
phox_mulder's Avatar
I try to remember to check mine at each fillup.
Haven't had a problem yet.
phox
Old 12-26-2004 | 03:51 PM
Forrest Nearing's Avatar
what brand BHAF are you running? I've never had a problem w/ Fleetguard or LubeFiner... just crank that hose down tight... never had one come loose.
Forrest
Old 12-26-2004 | 05:11 PM
infidel's Avatar
I've personally seen two popped off for who knows how long.
Big reason why I won't use one...
Old 12-26-2004 | 05:34 PM
If you put a short piece of 4" pipe or tubing inside the flange on the BHAF it will be much more secure. The BHAF is designed to clamp over a pipe, not to have a hose clamped over it - this leads to problems sometimes.
Old 12-26-2004 | 05:36 PM
Dr. Evil's Avatar
With a short chunk of 4 inch PVC pipe you can retain your filter minder (some people want to keep it even though it isnt all that accurate)...
Old 12-26-2004 | 05:39 PM
MasseyMan1089's Avatar
Hmm. I have a 4" chunk from the bottom of my stack. I think I'll use that...
Old 12-26-2004 | 05:58 PM
masonic-dodge's Avatar
I saw this posted about intercooler boots poping off and I think it would work for the BHAF's also.
I don't want to take the credit for it but they said to clean both surfaces and use Hair spray on both surfaces, let it dry then put it together. This sounds like if it will work on 50psi why won't it work on an intake.
CRIS
Old 12-27-2004 | 12:47 PM
BigBlue's Avatar
I've used a wix filter and never had any troubles before. Just cranked it down tight and that was it.
Old 12-27-2004 | 03:38 PM
LanceD's Avatar
I cut a 2 inch piece off the tip of my stock exhaust, fit perfect
Old 12-28-2004 | 10:36 AM
johnh's Avatar
Unhappy bhaf
i had the same thing happen to me, i don`t how long it was off
Old 12-28-2004 | 12:39 PM
vssman's Avatar
Mine popped off of my wix BHAF. I took two self tapping #6 screws and sent them through the clamp, hose and filter neck. Haven't had a problem since.
- Take the filter/hose assy off of the turbo and knock any chips out if you do this.
Old 12-31-2004 | 05:11 PM
willysrule's Avatar
Fleetgaurd one here....no problems...
but vssmans idea is what I was going to do if I had a problem...
Old 12-31-2004 | 06:34 PM
I SPEED's Avatar
I'm running the Fleeguard marine BHAF and check it on a regular basis. No problems to date.
On a side note, I have an Air Raid intake on my Jeep and that has popped off once.
Rickcher
09-02-2009 06:08 PM
Ace
10-31-2007 07:46 PM
danimal 95
18
11-17-2006 03:28 AM
Andrew k
05-03-2005 05:32 PM
tobyw
18
03-06-2004 07:42 AM
