To those with a 12 valve and an SPS 62 or 64
Old 03-07-2007, 05:49 AM
74dart's Avatar
Originally Posted by signature600
Good luck...but having been there, and spent a bunch of money trying to make it work like I wanted, no thanks! If I had back all the money I spent trying to make a 500hp 12v that could tow 25-35K, I would already have my new truck paid off
It's so much easier making HP when you don't have to worry about how it will act with 25K behind it, or if it will melt down with that hired man in there climbing a hill
I know why you're doing it the way you are, and I can appreciate that...but at the same time, I'm glad I moved on to a new approach!
Chris
Is that weight truck included? How bout a 13k trailer.? Im currently running a 60/12 and have high egts at wot while pulling but thought it was due to the smaller compressor housing. Should have got a 14 but love the lower spoolup at the track.
Old 03-07-2007, 08:01 AM
signature600's Avatar
Originally Posted by cumminsdriver635
I kind of wonder how an HX40 is too? I think an S-300 would be better though.. Its not as big as an SPS62, right?
Chris: I know what ya mean. But im gonna try this. You can say I told ya so if it doesent work out for me
Eric
S300's are tougher...if you wan't a S300 class, HX40 sized charger, go with a Super B/HTBG. You won't lose "much" spoolup if any, and it will cool better than any HX35 regardless of compressor wheel. I ran one for a while and was extremely impressed!
I wouldn't do that Eric...unless you fail miserably
Originally Posted by Ph4tty
How do you think the new silver 62 will compare? Think it's going to be a good alternative for the towing crowd?
I can't really say...I wouldn't think a charger built for nitrous would work for the towing crowd!
Usually, I list Gross Weight...the heaviest I have been was 38-39K Gross!
13K would be a warmup for my old truck...but you still know it's there!
Do you have to run WOT while towing? EGT's on a 12v are almost always controlled by your right foot
Chris
Old 03-07-2007, 08:17 AM
Mcmopar's Avatar
Chris,
Here's one for you!! My truck mods are listed below:
4" turbo back straight piped, AFE intake, 370 injectors, laser cut DV's, timing bumped, Number 6 plate in the stock position and the arm adjusted. I am running an HX-40/16.Oh, and a tranny with upgraded clutches. 6 in the direct drum, 5 in the low drum, and 6 overdrive. And a little billet here and there!!
The truck runs great, I tow at 15-16K with no problems, the only issue I have is full throttle runs or burnouts. I can see 1600-1700*F without much trouble. I have been considering an HTT killer "B" in the 64/14 configuration. Any comments??
Old 03-07-2007, 08:25 AM
74dart's Avatar
Chris
No I usally hold it to 2500 and the egts stay around 1050 while pulling 6%. That extra 500 rps would be nice though thats why I'm thinking of water meth.
Old 03-07-2007, 08:46 AM
Originally Posted by Mcmopar
Chris,
It will surge when towing unless you run in 3rd...at least every other 64mm charger I've played with has! If you can deal with that, I'd say it should cool it down fairly well. My GT4088R (63.5mm/.85A/R) runs great on the top end, but surges a bit going into OD...I think my 35's and 3.55's are aggrevating this more than normal
Water/meth is a good choice for using a smaller charger...I've never used it, but I've never heard anything really bad about it either! Use more water for EGT relief, say an 80/20 mix
Do you guys think I'm some kind of turbo Guru or something...my ignorance has caused me to try lots of chargers. I wish I could have just bought the right one first, but with a 12v there are TONS of varialbes that contribute to how good a certain charger runs over another!
Glad to be of any help I can be though!
Chris
Old 03-07-2007, 09:14 AM
Mcmopar's Avatar
Chris
Chris, define surge--Practical experience is worth more than book smarts!! To be honest, I am gonna learn from your "expensive" mistakes!!! Sorry!!! So are you running twins right now?
Old 03-07-2007, 09:30 AM
Nope, no twins...GT4088R on the 98, going back to stock (or close) on the 95! It's a shop truck now
Surge...I assume you know what "bark" is? Surge is a bark that happens when your still on the pedal. Basically, with an Auto, it will happen with a bigger charger when the tranny shifts from 3rd to 4th locked, or locks the converter in 4th.
It happens when the boost is "high" and the engine speed drops...the engine can't take in all the air that the charger is pushing. Usually you can drive around it by keeping in the pedal while it locks up in OD!
BTW, this is worse with 12v's than any other Cummins...because of the crappy head flow!
Make sense?
Chris
BTW, twins don't usually have this problem since it's splitting the load between 2 chargers...even though they push the same volume of air, the top charger is working half as hard, so it would take twice the effort to "surge"it. This isn't scientific, but it has held true for me!
Old 03-07-2007, 09:36 AM
Mcmopar's Avatar
What exactly is that GT turbo you have? Have you tried porting the cylinder head?
Old 03-07-2007, 09:42 AM
Not yet...that comes later. Ported head and Helix 2.
Here's my charger
Chris
Old 03-07-2007, 10:26 AM
Mcmopar's Avatar
Is that a direct bolt on? Where did you buy it? Is that the T-3 flange at the exhaust manifold?
Old 03-07-2007, 10:37 AM
Mike D's Avatar
Phil, It says T-4.
Old 03-07-2007, 10:43 AM
Mcmopar's Avatar
I guess I need to read more carefully!!!
Old 03-07-2007, 11:50 AM
Bolt on.
Nope...took me and a buddy about 15-20hrs of fabricating the wastegate spacer, downpipe, wastegate plumbing, oil and coolant hose, etc!
I bought it off Ebay
Uses a t4 inlet flange...as it worked out, Joe Hellman had a ATS manifold he welded a T4 flange on that I happened to acquire, so that was a big help
Chris
Old 03-07-2007, 02:27 PM
Hayseed's Avatar
So now it is "Chris the Turbo GURU"!!! Is a 62/14 not a good upgrade for the stocker? From everything I've read it seems to be the best. There doesn't seem to be much preference on whether PS or HTB2 though. I'm needing a new one and just curious, dang side play!!
Old 03-07-2007, 03:24 PM
Haven't you read the thread??
It depends on the application...so give me some more info
Chris
Quick Reply: To those with a 12 valve and an SPS 62 or 64
