Thinking about twins...
Are you planning to use your SB66 as a top turbo in this set? Or are you hoping to replace the SB66 with a twins setup?
If you're going to keep the SB66, you'll want a big bottom turbo. Think S480 or GT4718 as a minimum.
If you're just starting over, then you could go with a 4202 on the bottom or a K31.
It's really tough to make intelligent recommendations without knowing how much HP you want to run, what kind of trans you have (and how it's setup), the gearing and tire size of your truck, and how you use it.
Justin
Justin
Hohn seems to know his stuff (from other threads I have read) but dont sell the old school short.I run a 40/3B and love it. I weighed in at 24800 today and was able to pull a skyjack into a 4x4 only area where the inlaws live with no problems. Just have to know how to drive.
want to try and keep my sb-66, have a GB trans & convertor (triple), as far as fueling-- fass 150/150 @ 45psi, 3/4 draw straw with an-12 line to fass, an-8 line to p-pump,an-8 line from p-pump to aeromotive regulator,an-8 retun line to tank. 0-plate, J&L injectors 5x16,lazer cut dv's,drilled dv holders
scot
scot
dodgediesel
17
04-05-2011 12:21 PM
Stock 02
28
09-24-2006 12:09 PM
