thinking about p pump conversioin
Old 09-10-2008 | 08:33 PM
06er's Avatar
I know this is talked about some here and has been done. So what are the draw backs if any other than cost. My 01 is basicly stock except for the intake, exhaust and thw fass 150 system. I was thinking by the time that i replace the vp (sooner or later but havent yet) buy a chip that maybe that money would be better spent on the p pump?
Old 09-10-2008 | 10:00 PM
smokin95's Avatar
i have buddy that has an 01 6 speed and it has a magnaflow lift pump intake and exhaust and fire ringed head it also has the p-pump conversion and that truck flat out runs good!!! We have since put 4k kit in it and that really woke it up and is amazing!!! p-pump+24 valves= amazing
Old 09-10-2008 | 10:14 PM
dieselfan's Avatar
cons
timing isnt adjustable as easy as vp. power is not as variable as vp. kinda $$$
i want to p-pump as well, especially while my vp is still good.
Old 09-18-2008 | 04:51 PM
CGA03's Avatar
How much does it cost and any other draw backs??
Old 09-18-2008 | 08:54 PM
24valvepuller's Avatar
the kit minus the p-7100 is like $1500 from haisleys, pump would be another $1000-???? depending on how much you want. Don't let anybody tell you it isn't worth it.
Old 09-18-2008 | 09:05 PM
dieselfan's Avatar
that sounds too cheap. i thought it was more like 3500-5000 when its all said an done.
Old 09-18-2008 | 09:30 PM
06er's Avatar
local shop quoted me $5000 for every thing. But then talked me out of doing it
Old 09-18-2008 | 11:20 PM
ratsun's Avatar
Contact member ~ Tate ~ on this board
He did his 01 and can give you plenty of insight.
Old 09-19-2008 | 04:32 AM
Tate's Avatar
False. Its a 98!
It cost me a little under $4k to do it. $1800 for the kit from Schieds, $1000 for the pump itself, $700 for the 45psi FASS and then the rest for various odds and ends, like hoses. You will need an overflow valve, and someway to shut it off. The factory solenoid is the best way IMO, but I lucked out and had friends that gave me some 12v parts. Keep in mind, those are the prices I paid in Canada after exchange rate and shipping and the like. US residents should be able to do it cheaper than that without much trouble.
Paul, I got the F1's in the 12v on Monday. Installed them, took it for a drive, wouldn't boost over 10 psi and would barely smoke. Then we realized that we left the boost tube boot on the airhorn loose. Tightened it up, and WOW! What a difference. Can't wait to get the SPS62 on this engine to see how it really does.
Old 09-19-2008 | 06:52 AM
67HotRod's Avatar
Originally Posted by Tate
False. Its a 98!
How did you end up with a p-pump for $1000? I'd also like to do the conversion.
Old 09-19-2008 | 08:56 AM
you are right I was corrected on the price of the kit. $1800+ $1000 and up for the pump. I used a cable to shut mine off, for pulling you need a shutoff inside the cab anyway
Old 09-19-2008 | 09:40 AM
ratsun's Avatar
False. Its a 98!
My bad....for some reason I thought your 24v was a 01
I knew you would like those F1s, they are a awesome injector.
Did you do any port work to the 12v head?
Old 09-19-2008 | 10:49 PM
Tate's Avatar
Negative on the porting. Everything is still stock on the 12v except plate, timing, injectors and GSK. I do have a spare 12v head that will be getting o-ringed, and possibly ported a bit. We will see how that goes.
I was able to get the pump for $850 USD, that was with #10 plate, AFC springs and 4k GSK in it. Worked out to about $1000 CDN. I found it in the classifieds on here. And thats a 215 pump.
roxxx
09-24-2009 09:17 PM
patriot pearl blue
12-28-2002 10:03 PM
KevinR
12-05-2002 09:00 PM
Nashirak
17
11-22-2002 04:35 PM
BigBlue
33
11-03-2002 03:58 PM
