thinking of a 66mm turbo -input?
Old 06-03-2008 | 02:07 PM
  #46
Don Wagner's Avatar
I agree, but what do I know?
Old 06-03-2008 | 02:19 PM
  #47
dzlfarmboy's Avatar
Originally Posted by Don Wagner
like most people with an education I round decimals properly.
Im all about factual information to but dont appreciate someone implying a low blow towards me.
Brett
Old 06-03-2008 | 02:21 PM
  #48
Don Wagner's Avatar
Brett
That was directed toward the distributor, they should offer more accurate information. It was not directed toward you Brett.
Old 06-03-2008 | 02:23 PM
  #49
Lary Ellis (Top)'s Avatar
Admin Team Leader
I am simply telling the actual specifications of the turbocharger, maybe actual specific information on a product is not desired?
If you were only trying to give factual information, you would not have felt the need to place that insult in your post.
Don't pee down my back and tell me it's raining
Your information is welcome, the attitude isn't.
Old 06-03-2008 | 03:18 PM
  #50
Emoneysrt-6's Avatar
so does someone wanna answer my ??? or is this a angry thread now???
Old 06-03-2008 | 03:22 PM
  #51
RowJ's Avatar
Ditto....Post 39!
RJ
Old 06-03-2008 | 03:35 PM
  #52
Mike D's Avatar
http://www.dallasturbo.com/specials1.html
http://www.timsturbos.com/S400sx_Sling_Shot.html
Some info on the S400
Old 06-03-2008 | 05:06 PM
  #53
Don Wagner's Avatar
Originally Posted by RowJ
Ditto....Post 39!
RJ
S475 with the 74/83mm turbine wheel, 0.66AR compressor cover and 1.25AR T4 turbine housing.
Old 06-03-2008 | 05:12 PM
  #54
Mountaineer's Avatar
Ok were over it. I also appreciate factual information
Old 06-03-2008 | 05:21 PM
  #55
sorry to bug but how about post# 37 too
Old 06-03-2008 | 06:29 PM
  #56
Don Wagner's Avatar
Have you tried either the 1000 or 2000 version for the Adrenaline? Otherwise I might look into the injectors not working for your application, what hp rating are they? I would not recommend going over 50psi on the the 73mm turbine wheel due to drive pressure issues.
Old 06-03-2008 | 10:40 PM
  #57
11 hole 180hp with lift so who knows but im pretty sure they are just too big... its on the 2000 tune right now... and i was told 55 was where i should put it but if its a bad idea i'll turn it down a tiny bit....
Old 06-04-2008 | 10:07 PM
  #58
Mike Holmen's Avatar
The Guru
Forget the S300 and go with a garrett ball bearing turbo. It would works almost as good as twins with out twins. Cost wise it the same price, so why buy a S300? From my experience my garrett ball bearing will out spool a similar sized turbo. Why buy anything else??? I'm sold on the difference.
Old 06-04-2008 | 10:26 PM
  #59
Don Wagner's Avatar
I laughed.
Old 06-04-2008 | 10:28 PM
  #60
kas83's Avatar
I'm not sold on the difference. The higher loads place on ballbearing chargers with high boost/drive pressures dramatically reduces the reliability. You will NEVER get the amount of air a set of twins will move from a ballbearing charger that will still spool relatively quickly. Yes, you can go slightly larger with a ballbearing charger, and still retain some driveability, but the difference isn't that much.
