thermocouple break off?
Anyone hear of a thermocouple probe breaking off and going through the turbo??
Or of any probes breaking, no matter where they were located??
Big Jimmy
Big Jimmy
Nope, but I have heard that they can become inaccurate over time. It was a post by Don M of f1 injectors stating that he thought it was a bad idea to trust your pyrometer too much for that reason.
Yeah, actually I did hear of one thermocouple doing that but it is pretty rare - I would think an improper install would cause that to happen more than anything else.
Thanks. I am waffling about pre or post turbo.
Considering its easy to do the math to know what the egt's are when the probe is after the wheel I was wondering if there was much risk associated with its pre placement. I'll probably choose to live where every one else does on these forums, placing the probe in line as the first thing the turbo will eat if anything goes wrong.
Jimmy
Jimmy
Considering its easy to do the math to know what the egt's are when the probe is after the wheel ...................
Jimmy
Jimmy
Industrial applications that roun without wastegate and are stock will have no problems calculating the pre-turbo EGT at full power from a post turbo probe.
On a bombed truck I'd suggest going pre-turbo to know the EGTs instead of guessing
AlpineRAM
Agreed!
It's easy to do the math... if you add 500* to all scenarios! Need to do that to cover the occasional situations where it WILL be 500* difference.
The 300* difference used by many otherwise knowlegdeble Cummins experts only works for stock, long haul, big rigs (as mentioned above).
Why mess with guesstimates when locating pre turbo has been bulletproof for thousands of satisfied DTR members?
RJ
RJ
I look at over 100 engines a year with pyros mounted pre turbo, and per cylinder. I have heard and seen every type of failure and the pyro was never the culprit of turbo failure. To be honest I have seen pre-turbo pyros bent from being hit by debris from the engine and not break off. I would not hesitate to install pre turbo. A turbo is alot cheaper than replacing the engine if you want to weigh risks..
DTR's Cow Boss
the probes have broke when the probe was wrenched down in to the bottom of the manifold most of if not all the probes now being used a shorter verson so that does not happen.
big jimmy,
I have always heard about the "one that broke", but I have never been able to find any one individual that has had his break. It's always my father in laws mothers second cousin on the other side of the family kind of deal. Go pre and be happy, you'll be lgad you did.
Mark @ DPPI
Mark @ DPPI
Thanks everyone!
I'll be augering a hole in the exhaust manafold this Sunday.
Since I'm a woodworker I am going to make my own triple gauge mount out of some nice wood I've got- not sure on the exact location yet but not the pillar- thats not for me...
Big Jim
Big Jim
Thanks everyone!
Big Jim
Big Jim
J Lent
10-07-2009 06:50 PM
Chip
14
06-21-2009 03:59 AM
Red3quarter
09-06-2008 11:56 PM
pwabbott
10-28-2003 08:59 AM
