Is there a compressor housing gasket?
I did a boost leak check the other day and my compressor housing is leaking where it connects to the center section. Is there a big o ring there or some sort of gasket? I'm tired of my laggy stock turbo. Laggy due to leaks that is.
I went and looked on their parts page and it shows now o-ring on the compressor housing. Here is the link to the exploded diagram of the hx 35. http://www.htturbo.com/hp.html I hope this helps.
Joe
Joe
The HT3B I've had apart is just a metal to metal mating, no o-ring in it. I'd imagine the HX35 is the same. Did you make sure that the bolts on the lock ring are tight?
Sometimes the compressor housing snap ring is not seated correctly and will cause a leak. You might try getting in there with a screwdriver or punch and tapping it with a hammer to seat the clamp....that might seal it up.
WhoCares79
06-03-2008 11:45 AM
Camarogenius
06-25-2007 08:55 PM
