Terrible Clutch Screech...Normal?
Old 03-10-2008 | 10:10 PM
Plumb Wild's Avatar
I just put a DD HMR/McLEOD clutch from Scheid diesel, its pretty well just a pulling clutch. I have it very well broken in, but im experiency a bad screech out of it. I knew that DD clutches "chirped" as you shift, as mine does, but i've never heard one sound like mine does at take off. It is worse in second as compared to first gear. When i let the clutch out to get going it has a very loud screeching noise until the clutch is fully engaged. I called Scheid and they said its because it had an iron disk and its normal, but it just worries me...any thoughts or ideas? Any of you run this clutch?
Old 03-10-2008 | 10:24 PM
cswineford's Avatar
I have the same clutch have about 40 hooks on it and 20,000 miles. Mine always screeches and your right starting out in second is worse so I always start out in first unless i am at the drag racing track. Curt
Old 03-11-2008 | 12:42 AM
Tate's Avatar
I've got a Southbend, and it does that occasionally. More often when it was new. I wouldn't be overly concerned.
Old 03-11-2008 | 10:00 AM
stuckey200224's Avatar
my souh bend does it sometimes expecialy when towing. if you have the sinthered iron disks thats def normal. i know the ones for gas trucks squeal like a pig
Old 03-11-2008 | 07:05 PM
ILLINOISRAM's Avatar
Haisley's use sintered iron disc in their street puller. A buddy of mine has this clutch and it does the same thing. It is just the nature of the beast.
Old 03-11-2008 | 07:22 PM
Plumb Wild's Avatar
Good, that really takes a load off my chest. Im also very glad to hear it is holding up good with your miles/and pulling. Thanks for the input guys.
AJMartin0321
04-19-2009 01:40 PM
J_T
03-23-2009 10:59 AM
Rowan
05-03-2005 01:19 AM
LeVardi
02-24-2005 06:14 AM
miketriton
15
10-27-2002 07:08 AM
