Template for BHAF
Template for BHAF
Rattlin Ram,<br><br>On April 9, U posted a template pattern for a BHAF baffle.<br>Is the template full size, which way do you bend "A2", up or down, where does "A" fit and where does "B" fit ?<br><br>Thanks,<br><br>John Brockett
Re:Template for BHAF
I'm not RR, but I recently used his template to build the heat shield for my BHAF.<br><br>The template is fullsize and if you lay the eight sheets out, "A" is the left column, "B" is the right column, and "1" is the top row.<br><br>As for how to bend it, if it is laying flat as I described it above, the bottom of the template should be bent up along the dotted line.<br><br>I hope this helps!<br><br>Brad<br>
[quote author=MOSTWANTED link=board=7;threadid=14175;start=0#133395 date=1051667543]<br>I missed it :, someone post a link to this template Also,anyone like the bhaf over anythink else (besides stock?). Better than scotty?<br>[/quote]<br><br>I have the BHAF and like it. Better than Scotty? No, absolutely not. It's an evolutionary process I guess, at least for me. BHAF is better than stock and Scotty is better than all else, from all the comments you get on these forums. Personally, as soon as I finish building this BOMBING funds draining DECK, I'll be getting a Scotty II system. Just my .02 and 1/2 cents.<br><br>~thankgodforairnailersandscrewgunsan dbatteriesDave
Oh, I forgot, heres a link for the BHAF template.<br><br>https://www.dieseltruckresource.com/...p;onlynewfaq=1<br><br>and below is what one looks like when installed, as in my truck.<br><br>~Dave
My BHAF actually improved my MPG as well...I had been getting around 16 around town, thought maybe the BHAF was pulling in too much hot air, so i threw the stock air box back on...only to see my MPG go down to 14-15 on three consecutive tanks...And yes I do have the heat shield, similar to NWDave, but not diamond plate
mysterystench
10-25-2006 04:19 PM
