Temp gauge sweeping
Old 02-06-2006 | 06:39 PM
johnsjas's Avatar
Temp gauge sweeping
I was wondering if any of you has had a sweeping water temp , and how you fixed it. I have replaced the thermostat and the sensor. I have heard that a heater line runs into the t-stat housing and will cause it to open and close. To fix this they drilled a 2mm hole in the t-stat.
Any thoughts
Thanks
Old 02-06-2006 | 07:34 PM
turbox2's Avatar
I think that is normal mine sweeps from 140-190 all the time. Big radiator, stat opens down goes the temp. I had a 350 ford with a 460 that done that. I drilled a few holes around the stat ring and stopped it. But now I am older and a little wiser and I belive its supposed to do that. The cummins will steady out when pulling a load.
Old 02-06-2006 | 07:39 PM
johnsjas's Avatar
I dont see how that much change could be normal or good for the motor, but I could be wrong, and i dont pull
Old 02-06-2006 | 07:43 PM
turbox2's Avatar
Ahh 50* swing I dont think is bad. OK guys what do you all think?
mar67655
03-21-2009 06:35 AM
DennisT
05-11-2007 09:58 PM
Bad Ramer Jamer
12-01-2005 03:30 PM
firesine
11-24-2005 11:58 AM
