tapping vp44 wire
tapping vp44 wire
My warrenty is up so hiding the wire tap in not a issue, should I still get a cover or would soldering hold up and last a while? Just want the best possible conection. anyone have problems with there solder job or pump covers?
Rob
Rob
Oscaroc,
The cover we're talkin about is an aftermarket cover that fits on top of you pump that has a separate wire comming out of it just made for and aftermarket fuel module hook up. That way you don't have to tap in to your stock wire.
BD is one of the companys that makes them.
If your not worried about the warentee then save your money and just solder it, and dab a good RTV silicon on the conection to keep it isolated and weather tight. You cant get a better connection and you dont run the risk of cracking your circut board( ask Scotty) Just my $.02
The cover was the sneakiest way to get the connection.
If you're not worried about warranty, solder it, best possible connection.
Any of the other methods of piercing just contact the wire, and contacts can come loose.
phox
phox
If your the honest type and just want to make a good connection, try a Posi-Tap.
www.posi-tap.com
The Grabber is $20. The Posi-Tap is $1. Both make good connections, but the posi-tap takes up less space.
Soldering is great, but you can risk damaging the pump wire, or worse, cutting it!
Scotch-loks are OK if you hold them still when closing them, and then never let them move again.
I have yet to see something that makes a better connection for lower price than a posi-tap.
JMHO, as always.
www.posi-tap.com
JMHO, as always.
Buckshotmckee
07-29-2016 02:11 PM
TPilaske
16
11-22-2002 08:15 PM
