Tamper Proof Screw
Old 07-09-2005 | 05:00 PM
AllPlay's Avatar
Tamper Proof Screw
What is the best/easiest way to remove the tamper proof screw on the afc housing? Any other suggestions on sliding the plate will be helpful too. Thanks in advance.
Old 07-09-2005 | 09:17 PM
Rattlerattle's Avatar
I used a chisel and hammer. Chisel a side of the screw in the direction to loosen. An impact driver is supposed to work well, I didn’t have one at the time of doing my plate.
Old 07-09-2005 | 10:13 PM
Cummins4Life's Avatar
I drove a flat screwdriver down into it and backed it out like a regular screw.
If you want to replace it its 6.0mm 1.0 pitch thread about 1/2-3/4" long.
Old 07-09-2005 | 10:39 PM
infidel's Avatar
My favorite method is a cordless drill with a counter clockwise drill bit. For me the bit has always caught and turns the screw out. Even if it doesn't once the head is off and the cover removed the screw will come out easily with pliers.
CC wise drill bits are usually with the bolt extractors at most hardware stores.
Before moving the plate scribe a line on top of the housing even with the front of the plate to mark the stock position for future reference. I find the most power from sliding the plate 1/10" from full forward. Most times the plate screws are very tight, an impact driver, the kind you hit with a hammer is usually in order. Impact drivers are readily available for under $15 and are an essential tool to have.
Make sure when you put the cover back on that you slide it full forward.
Old 07-10-2005 | 06:15 PM
AllPlay's Avatar
Thanks for the help. Plate is now moved foward and the housing also. I had already turned the starwheel so this put the icing on the cake. Now to get some gauges and the 4" exhaust should be here Wed. Nothing but fun. Thanks again.
Devil Dog 6227
08-08-2013 10:26 AM
lobes1985
07-08-2008 11:04 PM
Dusty Ratcliff
05-23-2006 11:05 PM
TexasHardcore
10-26-2004 06:43 PM
Cummnzpowr
06-04-2004 01:57 PM
