Taller Tires
Taller Tires
I currently run LT265/75R16 tires on my 2 wheel drive.
I installed a 1.5" front leveling kit. What size (taller)
tire can I fit to fill up the wheel wells without rubbing ?
I don't need to go wider ,just taller so I can use my
factory alloy rims.
factory alloy rims.
I just put on General Grabber A/T 2's 295/75/16 no problems at all....they are taller than the 285's and taller and narrower than the 305's:
http://www.generaltire.com/generator...enefit_en.html
Very happy so far....
It is my understanding that you can get 315/75's on there with a leveling kit, and stock rims. They'll rub the tracking arms on the inside a little in sharp turns though. I have a set now, and as soon as I modify my 99 truck to take these 2001 alloy rims, I'll take a picture to show you.
Chris
Chris
315s on stock rims are pretty narrow and they should rub the inside pretty bad in parking situations.
I had 295s on my stock rim and they rubbed pretty bad. When they wore out I put 305s on new 16x8 rims and they don't touch at all. I do have 2" lift on mine though.
Re: Taller Tires
Originally posted by Dieselcamper
I currently run LT265/75R16 tires on my 2 wheel drive .
factory alloy rims.
factory alloy rims.
sakisaki400
23
12-31-2006 11:17 PM
Dieselcamper
03-08-2006 03:29 AM
ledj
09-09-2005 01:37 PM
