Tail Light Blinkers
Old 01-01-2003 | 10:33 PM
CRobey4393's Avatar
Tail Light Blinkers
Here is a pic of the diag. to make the Tail Lights Blink. It works with the lights both on and off.<br>Thanks<br>Chuck
Old 01-01-2003 | 11:39 PM
Stamey's Avatar
Re:Tail Light Blinkers
Would this really be advantageous? I'd think people would mistake it for turn signals (most don't pay attention to whether it is one or both sides), or hazard lights. What happens when you are actually braking and have your turn signal on? Normally the tail light with the signal blinks and the other one stays on. If I used this wouldn't my lights just blink like hazards? That seems like it would be more dangerous, in some situations.<br>Now if the brake light blinking were set up in such a way as to strobe and then stay one for a few seconds, then strobe again. That is a very unique pattern and would surely get peoples' attention. It might require LED bulbs though.<br><br>Could this be only for the third brake light? I could see where that might help.<br><br>Chris
Old 01-02-2003 | 06:25 AM
CRobey4393's Avatar
Chris,<br>I set this up for when I pull my trailer. It will blink the trailer lights, just like the 18 wheelers when they pass.<br>Chuck
Old 01-02-2003 | 08:07 AM
Stamey's Avatar
OK, maybe I'm just out of it. I haven't seen that sort of thing here in Virginia. Maybe it's a Mid-West thing?<br><br>Chris
Old 01-02-2003 | 09:56 AM
Evildiesel's Avatar
I see it all the time when you flash one an &quot;all clear&quot; to make a lane change in front of you. I do it too even tho I'm just a lil hauler (must be the stacks)
Old 01-02-2003 | 10:53 AM
atc250r's Avatar
Same here, learned it years ago when doing some trips back and forth to Detroit to drop off press cars. It's just a courtesy trucker's extend to each other and alot of them will give you the same courtesy if they see your pullin' a decent size trailer.<br><br>John<br><br>
Old 01-02-2003 | 09:46 PM
Stamey's Avatar
Sure, I've seen that many times, but that only concerns flipping the parking switch switch in the cab, which, on big trucks, is separate from the headlights. What Chucksram is talking about is blinking brake lights, and that's what I have not seen. As I said, I think it has potential, if it cannot be confused with signal or hazard lights.<br><br>Chris
Old 01-03-2003 | 06:20 AM
CRobey4393's Avatar
Stamey,<br>The diag is for the tail lights, not the brake lights.<br>Chuck
Old 01-03-2003 | 09:29 AM
jfpointer's Avatar
[quote author=Chucksram link=board=7;threadid=9076;start=0#87172 date=1041478407]<br>Here is a pic of the diag. to make the Tail Lights Blink. It works with the lights both on and off.<br>Thanks<br>Chuck<br>[/quote]<br><br>ChucksRam,<br><br>What kind of switch is that? Some kind of momentary? This seems a bit safer than turning off the headlights to flash the tails, which is how I'd have to do it now... Thanks
pjc360
01-11-2018 02:15 PM
Chessbay
05-07-2013 04:07 PM
WestTexasRam
01-05-2010 08:01 PM
Viperdew
01-02-2009 01:13 AM
TGriffith
12-08-2006 11:34 AM
