Switched VP tap?
I'm sure its not much but I'm wondering the need for it. On most box's that tap the wire they have an off level (1 or 0) which is just timing or no extra fuel and you can switch it off anyway. no offence but i don't see the need. However I dont think you would melt a switch or anything.
AFAIK, it is not an on/off signal that goes through the wire, but the timing (pulse) signal for injection duration and timing. A switch IMO would accomplish nothing.
EDIT : I misunderstood the question.
Are you trying to switch the output of the Banks module to the VP wire? If so then that should work.
someone did it a while back, and posted it on here, it didnt work for him, you might wanna search for the thread... i dont know how it turned out...
the wire of the drag comp on my 01 has always been tapped from day one i bought the comp
Someone posted this very question a few weeks back and I don't think there was ever any resolution to it. IIRC, they couldn't get the switch to work properly... something about it would work only one time and then not again.
LovinTheTorque
09-14-2013 12:02 PM
glarior
05-17-2011 07:46 PM
bgilbert
03-02-2006 04:01 PM
