SWAYIN' Cummins
SWAYIN' Cummins
I have an 02 sport and on the highway it sways back and forth, ya have to hold on to the steering wheel and if u let it go, ur in the ditch. LOL .. I got an aliment, new track bar, ball joints, and the wheel braerings are good.....(Now)....
and it still floats..? I noticed the other day that there is a sway bar in the front, the ball joints are gone where it connects to the axle... Just wondering if this could be my problem or is the box just gone..? I drive alot of dirty rough roads... I know that the front ends are not to withstand that but... i don't have a choise thats my job.
Just Looking for some info or simular problems
VJ
VJ
http://www.solidsteel.ca/DSS.htm
This may be what could help you out. Supports the sector shaft in the steering box, makes everything more rigid. I've heard nothing but good things on these.
Pretty sure solidsteel.ca is out of business.
The DSS helps me stay in the lane I'm shooting for.
Sounds like you have a steering box problem as well.
Might be best to replace it, then install the DSS.
As to the front swaybar joints being bad, I took mine out completely over 2 years ago, don't even miss it or notice that it's gone.
phox
Do, ya think there is any test i can do on my streering box to let me know../?
if thats it or not.?
Anyone know a price on one.?
and iam deffently lookin into that stabiler thing!
I had a major tire store align the front end on one of my trucks 4 times, telling them each time that the toe-in should be negative 1/8". After narrowly missing several wrecks I finally adjusted toe-in myself with a tape measure, to 1/8" in, and no more problems. Could be the shop left you with zero toe, or positive toe-out? You want at least 1/16", and I like 1/8" ideally. Measure across the front of tires and then rear of tires, at center point top to bottom. That will tell you where the toe-in is, and then you can have it adjusted if it's wrong.
JimmieD
JimmieD
Here's some links that may be helpful. Firm Feel is currently rebuilding a manual box for my '67 Dodge truck, and I think they can rebuild most anything, power or manual. I got a good price and they have a good reputation, and very friendly and personal on the phone:
http://www.firmfeel.com/default.htm
I haven't had any dealings with these, but they might be able to help you if Firm Feel can't? I mainly do vintage stuff so not sure what they carry.....
http://store.meridianautoparts.com/M...y_Code=DODPICG
http://www.buy-steering.com/Merchant...ry_Code=DODPIC
andyboland
21
01-08-2020 11:32 PM
ProjectM880
12-01-2004 06:40 PM
