sway bar spacer block
on my crappy lift kit (RCD) my spacer blocks for my sway bar up front is about 2" its a c-channel shape its old and starting to cave in some. does anyone make a aftermarket replacement for this. if not I can always make a new or fix the one I have. this is a older picture of it when it was fine. but you can see its not fully boxed.
https://www.dieseltruckresource.com/...8&d=1253062315
Vendor - Former Vendor
I bet your cheapest and easiest option would be to take them to a welder and box in the areas that can be boxed in without interfering with your steering box brace.
yes the RCD has been a constant heartburn.......I have called them many times... and its like talking to someone that that has no clue
yes I'm having them boxed in this month, good cheap plan
tcr
12-04-2007 12:15 PM
Robert373
04-03-2007 12:20 PM
