Swapping in a 12valver into 2002 24v auto
Old 06-03-2006, 08:31 PM
The Guru
Mike Holmen's Avatar
Ok guys I'm going into unknown terrority. I just toasted my 24v and I found a cheap low mile 12v for $5can for sale. Its low miles and complete from turbo, injection pump, starter, fuel pump and so on. Next question does a guy do this swap??? I also found a used 02 but its more money and not so complete just a long block and its stripped down. My 24valver has a bad knock now, it giving me the shivers. So also how can bomb a 215hp 97 into something that will at least move my truck around.
Old 06-03-2006, 08:58 PM
heatedwheels's Avatar
http://www.dynomitediesel.com/ these guys have done it
Old 06-03-2006, 09:19 PM
Mountaineer's Avatar
Mike
What do you think caused it to start knocking?
Old 06-04-2006, 09:31 AM
The Guru
My heavy foot and pulling something heavy. Has anybody done this swap?? I think that it would be easier than putting in another 24v motor and trying to get the computer to like the new electronics. I know PDR has done this to lots of trucks but the guy that I talked to didn't know if my cruise control would work. I've heard that you have to leave your VP hanging there. I've always wanted a P-pump motor so I can build a killer engine. I've been throwing around the idea of mixing the parts together and building a neat driver. A 12v bottom end, 24v head, mach 6 injectors, new injector lines and a tricked P pumped. I just don't know how the stock 12v bottomend would like that much power. PDR guys wants me to buy all new 12v stuff. On my budget its not going to happen.
Old 06-04-2006, 04:13 PM
cummnz4x4pwr's Avatar
you cant use the complete 12v bottom end you are going to need 24v pistons... preferably from a 3rd gen. they have a nicer bowl design.
jake
Old 06-04-2006, 06:36 PM
GlennRMK's Avatar
You will probably need a 98 Gauge cluster for the gauges to work
Old 06-04-2006, 06:50 PM
Forrest Nearing's Avatar
jake
why would you use 24v pistons w/ a 12v head?
Old 06-04-2006, 11:03 PM
displacedtexan's Avatar
jake
He is swapping the whole engine, why won't the pistons in it work?
Old 06-06-2006, 08:22 PM
The Guru
No I was just thinking about running my tricked out head on the 12 v short block. Why can't the 12v pistons work with a 24v head? If I rebuild I plan on getting a set of forged pistons that have some heat resistant coatings on them. File fit rings would be nice to.
Old 06-06-2006, 08:58 PM
b/c the fuel bowl is offset for the 12v injector spray.
And you can make your cruise work its basicly like doing a p-pump conversion, you just use your apps and put a 1" spacer on the backside of it then use a 1 1/4 inch spacer and weld it to the bottom of the apps bracket and then bolt it on and plug it in.
jake
edit: another thing all the cummins pistons are forged, so you can run the 3rd gen pistons and decompress, coat, or flycut them for a lot less money. and have a longer lasting setup since the aftermarket pistons and rings are usually only good for about 50k
Old 06-06-2006, 09:01 PM
oh this is for Forrest and displaced.
Old 06-06-2006, 09:04 PM
DWeiler's Avatar
Sorry to here about your ride Mike,hope you can get thing working again,sucks when you play and then gotta pay. GOODLUCK DW
Old 06-06-2006, 10:10 PM
I totally missed that
Old 06-07-2006, 08:42 AM
jeez, so did I
carry on!
Old 06-09-2006, 01:07 AM
The Guru
Heck its only money. At least this gives me time to redo the things that I didn't like the first time around. Like a less laggy top turbo, more heat resistant pistons and one heck of a p-pump. The old bottom end kinda had too much vibration anyways. A good balance job and a good balancer should fix this issue. Hopfully by the end of summer I could get this monster together and get a dyno run on it. It sucks not having a 24v rattling at the stop lights. The old ddp injectors that I had kinda reminded me of my muscle car days with the radio antena shaking. To bad the power was so far off. Their making me some P-pump injectors for my 24v running some killer flows.
Quick Reply: Swapping in a 12valver into 2002 24v auto
