Surging Comp Smarty stack
I tried searching, didnt find anything can anyone point me in the right direction to fixing this? I can turn the comp off with the cruise on and it goes away but thats not very fun lol.
If you run SW5 or greater you will get cruise surge without a load. I can run SW5 with a 7k load and it is just past the surge point in cruise. My 4.10 gears probably soften it a little however.
My fix was to install a piece of red tube from a WD40 can into the vacuum line going to the cruise control. Not sure if the 5-speeds are vacuum controlled or not on the 99's. It worked on my auto.
Mine had a bad surge. That's why I sold the Smarty. It seems to affect the built auto guys that run fast spooling chargers and big sticks with higher gear ratios.
Mine surged so bad with the Smarty alone on level 3 or higher, the cruise was useless. The throttle was just too touchy.
Put the thing in my dad's stock truck, he doesn't notice a thing.
So, it depends on the setup. You have to understand what is adding fuel and when to get a clear picture of a "fix". I have been asking for help with it for almost a year and gave up.
Dave
Dave
dodgediesel
07-27-2007 09:59 AM
dieselbeef
07-27-2007 02:21 AM
whitestreak06
06-08-2007 02:29 AM
bignastydodge
03-29-2007 08:36 PM
