Superior ShiftKit
Old 06-28-2004, 05:29 PM
INJECTOR JACK's Avatar
Question Superior ShiftKit
Somebody refered a Superior shift kit over a Transgo a while back I was wondering what the part # was for the kit? I did a search but had no luck.
Old 07-02-2004, 02:12 PM
whazzup's Avatar
Do not know a part number, however here is a phone #214-920-7021 ask to speak with Gordo. The outfit is in DFW somewhere ATC-Repco is the name.
Old 07-03-2004, 11:15 AM
Shift Kit
Thanks for the help, Superior e-mailed me back with a phone# for there tech line I'm going to give them a call.
Old 07-09-2004, 07:10 AM
FANZDSLPWR's Avatar
why superior over a transgo?
Old 07-09-2004, 10:00 AM
shift kit
They are a better kit I hear you don't have to change any wiring just a straight parts swap. I have not heard anything to positive about Trans go kits
Old 07-12-2004, 11:18 AM
SHARPMACHINE's Avatar
Any updates on this ? I've been considering a shift kit when I change my T.C. and am looking for ideas.
thanks
Old 07-12-2004, 11:23 AM
Mcmopar's Avatar
SMR in canada has the BEST kit that I have ever seen, I have done many of these kits, no electronics mods either. I have installed the transgo kit, it works pretty well, and cost is about 75 bucks. Most of these kits are around the 100. dollar mark. The SMR kit is about 150.
Old 07-12-2004, 11:35 AM
2500TurboDodge's Avatar
what does the shift kit do, how does it work
Dan
Old 07-12-2004, 11:40 AM
2500t.d. the most important thing that they do is increase line pres. which helps keep your T.C. alive. They also "firm" up shifts etc. etc...
Old 07-12-2004, 12:11 PM
Mcmopar's Avatar
That's not entirely true, the valve body "shift kit" as most people call it does many things, one is increase the line pressure, but they also:
improve oiling to critical parts of the tranny
stop converter oil drain back
decrease overlap when shifting
change shift points to better optomize engine power
increase oil flow through the oil cooler
allow you to hold gears in some situations
lock up the torque converter in third(some trucks will some won't when stock)
Old 07-15-2004, 08:30 AM
Mcmopar,
Could you or someone else tell me how to contact SMR as I would like to investigate them. thanks...
Injector Jack,
What did you learn from superior and what was their number I'm trying to decide on a valve body upgrade myself. thanks...
DTR rules!!
Old 07-15-2004, 09:38 AM
Talking Shift Kits
Superior Transmission and SMR Motor sports both have web sites you can check out there tech lines are listed on the sites. I have not had time to contact them. I am getting ready for a long needed holiday. When I get back i will get into shift kit mode.
Hope this bit helps the SMR kit looks real nice.
Old 07-15-2004, 04:43 PM
Mcmopar's Avatar
Here it is!!
SMR TRANSMISSIONS & CONVERTERS
3030 CONCESSION 8, R.R.#2,
BRADFORD, ONTARIO L3Z 2A5
call: 888-846-6603
smr.motorsports@sympatico,ca
Old 07-16-2004, 09:02 AM
Mcmopar,
Thank-You
I see that they make converters as well, I wonder if those are good to??? as I am trying to make a converter choice at the same time.
Old 07-16-2004, 09:11 AM
Mcmopar's Avatar
I cannot comment on their converters, other that they make good ones for the old 440's that I play with.
Quick Reply: Superior ShiftKit
