superchips users
Old 12-03-2005 | 08:00 PM
cujo's Avatar
superchips users
Just installed mine and really like it. Which level of tuning gives you the best increase in MPG?
Thanks
Old 12-03-2005 | 08:30 PM
roysleight's Avatar
I couldn't really tell you what difference it's made. I didn't really install mine with MPG in mind. I have it set to the max setting and just smile as I go. Enjoy!
Old 12-03-2005 | 08:50 PM
Tommy93w350's Avatar
I want a chip or box, why did you pick the Superchip over Edge or Van Aaken? Is it the price, performance, availability, or options?
I've heard good things about the Superchips, enjoy!!! I'm jealous
Old 12-03-2005 | 10:02 PM
roysleight's Avatar
I liked the ability to change the programming and not have any connections to make with wiring. The price was really attractive in comparison to the chips and I was able to get a great deal on eBay. A big factor was the capability of reading diagnostic codes and also being able to reprogram the speedo/odometer for different tire sizes. You can't do that with chips/boxes, etc. Think about it.
Old 12-03-2005 | 10:29 PM
GSP's Avatar
GSP
Im courious about the superchip tuner ,edge ez,vanaakin too. What about this quadzilla thing???
I was told,,,( maybe ********) the super chip reprograms the ECM and the ez and van aakin alters the program comming from the ECM. ????
Who realy know whats going on !! ?? Seems most people just buy stuff and dont have a clue what the h*ll they are buying.
Old 12-03-2005 | 10:43 PM
roysleight's Avatar
If it works why do you need to know if it's before or after or under the ECM? You just have to learn to use it the way it was designed. Simple as that.
Old 12-04-2005 | 12:11 AM
GSP's Avatar
GSP
Thats about the most ignorant statement ive ever read
Old 12-04-2005 | 03:31 AM
oestreich84's Avatar
My VA brand new with the warranty and shipping included was less than $250. Plus with the Van Aaken or EZ, you get a built in boost fooler. So in the future you can add some injectors and not have to worry as much about egt's. I also hooked up a toggle switch inside the cab, so if it gets slippery outside I just turn it off.
The van aaken and ez alter the signal going from the ecm to the vp and map sensor, and the superchips tuner just re-flashes the ecm.
Old 12-04-2005 | 11:47 AM
high country's Avatar
the perf-tow mode works best for me it pulls hard on the bottom and does not give up much if any on top, the superchip reprograms the ecm like the mad ecm, the va and ez, comp etc. are signal altering boxes, you can run both at once, performance wise the superchips is not up to the ez or van aaken but worth the $$$ if you need a scanner or want to adjust tire size
Old 12-04-2005 | 11:35 PM
I thought the Superchips tuner advanced timing. If it does you dont want to stack it with another timing box You could stack it with a tst or some other fuel only box, but then you would need a boost fooler to keep egt's in check.
Old 12-04-2005 | 11:39 PM
drew03's Avatar
i am pretty sure the edge ez just fools the the map and boost sensor, as well as modifying the signals and such.
someone correct me if im wrong
Old 12-04-2005 | 11:45 PM
Originally Posted by drew03
i am pretty sure the edge ez just fools the the map and boost sensor, as well as modifying the signals and such. someone correct me if im wrong
The MAP sensor is the boost sensor If you go to a dealer they almost always call it a MAP sensor, and if you go to a Cummins shop they call it a boost sensor.
Old 12-05-2005 | 12:06 AM
GSP's Avatar
GSP
I wish there was some imformative literature writen by someone very knowledgeable about these products and hotrodding cummins. Remember the old "how to hotrod" bigblock chevy etc books.
Old 12-05-2005 | 12:12 AM
drew03's Avatar
whats the other plug go to is it a fuel pressure sensor?
Old 12-05-2005 | 12:16 AM
1qckdodge's Avatar
When I ran my superchip programmer I used a boost fooler, and installed a manual boost controller, I set it at 25 psi and the truck ran great.
