superchips stack
superchips stack
I know superchips has a programer out now for the dodge 24V I was wondering since it is a download if I can use it with my edge comp?
Re:superchips stack
There was a thread on this last week or so. You can use the programmer with your comp. Besides for more power, it will compensate for larger or smaller tires, and clear codes. You might try doing a search.
1 Post
Re:superchips stack
I was talking to Rod at Wildcat and he said that they dont work by themselves very well but seem to do some when its put on with injectors but said its not worth the money for one. Thats all i know about them
Re:superchips stack
I have been trying one for a while. It does not add as much as the EZ, on any of it's settings. I stacked it with a comp and liked it until I got on it. I think it is too much timing advance, I could not hear the engine but through the exhaust it sounds like its missing badly above 2600-2700 RPM's. I will follow superchips directions and not use it with any other mods. I think it would be great with injectors, but I still prefer the EZ. There are cheaper ways to fix the speedo for larger tires.
www.westtexasturbodiesel.com
Re:superchips stack
What are the cheeper ways to adjust speedo for larger tires? I have the 90 hp injectors. I like my comp better than the superchips as far as power goes.
Re:superchips stack
This will work, it's not quite as easy as the Superchips Micro Tuner. Here is a link with some info https://www.dieseltruckresource.com/...threadid=18176
Contact me if you have questions.
HOdiesel80
03-22-2007 12:19 PM
TorqueJunkie
18
08-30-2006 11:51 AM
thecatsfan
02-11-2004 01:58 PM
Cat Cracker
07-14-2003 12:17 PM
