Superchips Prgramer Questions
Old 03-11-2005, 01:35 PM
high country's Avatar
try here http://www.usdieselparts.com/1055920.cfm
GREG
Old 03-11-2005, 03:49 PM
joefarmer's Avatar
Originally posted by kyle@ftlb
The dyno runs were never printed off the computer. I'll have to see if they are still saved on the machine.
Thanks Kyle! I have Mustang and Dynojet viewers so emailing the files would be fine with me.
brnadon.
Old 03-12-2005, 09:09 PM
Turbo Deeezle's Avatar
GREG
Cool.. I'll check into that.
Old 03-12-2005, 09:15 PM
INSTALLED THE PROGRAM AND SET OT ON "TOW/SAFE" TODAY
I was thrilled to see that much of a gain on the lowest setting! I was happy to have my speedo and odometer back to normal again as well. A few things are bothering me though. When I step on the pedal, smoke pours out the exhaust..... I'm in So. Cal and this is no bueno. Why is this happening? I cant tell what color it is because it was dark when I was test driving. Another thing is that my trans seems to slip when I hit it quick and most noticable with overdrive on. Trans going south? Truck has 130k
Old 03-13-2005, 10:33 AM
The smoke is performance in action, more poop = more poop so to speak,being in so cal you know about that carb stuff, I don,t know if the programmer is ok or no, but when they open the hood and there is nothing there you should be golden I can't help you on the tranny as I am a manual guy but it sounds like a limited life by your decription....hope I am wrong
GREG
Old 03-13-2005, 11:21 AM
Hmmm... so the smoke is normal then, huh? Now with the boost fooler that I am going to order...what will this give me? For $55 I may as well give it a try.
I am going to take the truck into the shop and start out with a transmission tune up and band adjustment. I know its about time for servicing anyways. Thanks for the feedback and I'll post my progress.
Old 03-13-2005, 11:58 AM
the boost fooler will keep the truck from defueling you will see more zoot plus it will let you fix the wastegate to let it build more boost thus compunding the performance gains.
Old 03-13-2005, 11:21 PM
CRT
CRT's Avatar
I have a SuperChips, set at whats called "Safe Tow" and it worked just ok, untill I blocked off the waste gate, Now I get 29 PSI of boost and the truck tows like a dream. Stays in overdrive wile towing up hills. I never tryed the other setting cause the converter & trans are stock. This summer, I will be adding a good converter, input shaft & hub, and good alto red line clutches, billet servos and so on.
Old 03-13-2005, 11:33 PM
Re: INSTALLED THE PROGRAM AND SET OT ON "TOW/SAFE" TODAY
After tearing around today I noticed that the smoke is black.... and plenty of it when I stomp on the pedal. I still cant beleive the extra power I'm getting on the lowest Tow Safe mode. Gotta get the boost fooler and eventually a rebuilt trans and t-converter and try the other two settings........ but for now the Tow Safe is more than I expected.
Old 03-14-2005, 06:02 PM
I see that this programmer says it is locked into my truck only. I was not aware of this and wanted to pep up my bro's truck too. I also see these things for sale used?....... even on this board I have seen used Superchips before? Whats the deal?
Old 03-14-2005, 07:16 PM
phox_mulder's Avatar
Basically it trades the programming.
It puts it's program into the ECM and puts the stock ECM program into it's memory.
One truck per programmer.
Ones you see for sale are most likely because the person got bored with it and wanted more so they got a Edge Comp or other fueling box.
Hopefully they put their truck back to stock before selling it.
phox
Old 03-14-2005, 10:42 PM
TEXASTURBO's Avatar
So does this mean they cant be used on a different truck?
I have a EZ and a Blue Chip APB . Im thinking about buying one of these so i can lock up my converter. I havent installed the APB because of the wire tap.[ warranty]
Old 03-14-2005, 10:43 PM
justinp20012500's Avatar
brnadon.
Where do I get this "viewer" you speak of???
Thanks,
Justin
Old 03-14-2005, 10:50 PM
you can use a programmer on a hundred trucks, but each one needs to be returned to the stock program before programming a new truck....or call marco
BIG MEX
07-19-2009 09:46 AM
finndogg54
14
05-28-2007 11:02 PM
mx684
04-07-2007 09:55 PM
HOdiesel80
03-22-2007 12:19 PM
greenwing
12-01-2004 10:31 PM
Quick Reply: Superchips Prgramer Questions
