Super PhatShaft 66
Old 04-12-2008 | 05:25 PM
  #31
Don Wagner's Avatar
Originally Posted by Mountaineer
Sounds like you have real world knowledge and experience. That probably helps educate readers of this thread.
Here is a bit of knowledge that the readers of this thread may be interested in. The primary turbocharger in BD's street twins is basically a Silver Bullet with a slip-cover compressor and 1.10AR T4 turbine housing.
Old 04-14-2008 | 02:28 AM
  #32
HOHN's Avatar
Originally Posted by Don Wagner
But a person with first hand experience can.
No, the injection method will dictate how a turbocharger reacts to much more of an extent. I have heard of outlandish reasons for the difference in the '01-02 compression ratio between the standard output and the high output. Yet the truth is the SO piston bowl is 2mm larger than the HO piston bowl 59mm to 61mm. Those that know do, those that don't talk.
Ok Don--
You're welcome to continue denouncing "talkers" if you like, but if you have a beef specifically with ME, I will await your PM and we can iron this out.
The difference in compression ratio between two engines is well known, and changing piston bowl volume is easiest way to do it. What examples of "outlandish reasons" have you heard? It's one thing to comment on the MEANS that a change was effected-- it's another to comment on the ENDS of that change. To which are you referring?
Maybe you'd care to explain WHY the factory has changed compression ratio from 16.4 on the SO trucks to 17:1 on the HOs to 17.2:1 on the later HPCR trucks.
With that, I'll conclude my involvement in this thread.
Old 04-14-2008 | 02:03 PM
  #33
Don Wagner's Avatar
I'm sure I have never heard there being a 2mm difference in piston bowl size between the SO and HO, some form of different piston bowl design has been stated, along with headgasket differences, and head design differences, but never substantiated.
Emissions, lower static timing with a higher compression ratio.
Ph4tty
54
10-14-2012 03:46 PM
BurrisWill
01-27-2009 09:00 PM
diggity dodge
04-17-2008 06:05 PM
badcompany
31
02-01-2008 12:14 PM
caleb c.
09-04-2006 11:53 AM
