super chips programmer?
Re:super chips programmer?
Doesn't matter to me about warrenty I was just wondering, if you guys suggest this or the edge EZ. Keep in mind the price differences!!
As far as the check engine light, you can see what code is causing it, and there's a manual telling you what all the codes are. You can also turn it off with the programmer.
I really don't know about whether this is better than the Edge, since I have a 12V and I only used the programmer on a Powerstroke. From my understanding, you could get the programmer and then stack that on an EZ if you have a fat enough wallet.
[quote author=phox_mulder link=board=7;threadid=17998;start=15#msg169277 date=1060227764]
Question, does the Superchips incorporate a boost fooler, as the Edge products do?
phox
[/quote][quote author=TxCummins04 link=board=7;threadid=17998;start=15#msg169291 date=1060229831]
Are you talking about so the check engine light wont turn on?
[/quote]
Not only does it throw a code (check engine light) but the truck defuels to stop the overboost problem (I think).
phox
phox
[/quote]
phox
So wait, I asked a friend today about it and he told me that you should be able to take it out and program other people's trucks too. Is this true? Then I could kinda make my money back on the cost of it. What are the different levels I can program it to hp and torque wise? This sounds like an awesome idea, what do you guys think?
Once you use it on your truck it stores your stock program in the Programer there for you can not use it on other trucks.
I've never seen one on a CTD but alot of the Power Stroke guys run them around here.
IMO an Edge EZ or a Power Puck would be a better investment for you CTD but that's just my opinion. : You can find used EZ's on the TDR classifieds all the time for cheap. That's where I got the one I run on my 99, it doesn't have any stickers on it but works great with the TST box. 8)
DB
DB
The SC programmer does not have the punch of my Comp box on the EZ settings. It does fuel more, and adjust the timing for performance. I would suggest trying one before you buy it. Most shops will allow you to load it up and try it for a day or two before you buy it. It does have it's high points, but I would never give up my Comp for one. I run them stacked together and seems to work ok. It will also adjust for tire size and towing medium / heavy loads. I paid $275.00 for mine and it was worth every penny. Now all I need is a turbo. LE
I will not be on the dyno until next month so I cannot say for sure, BUT, the Superchips programmer is set @ the highest "performance" setting and if I had to guess I would say maybe a 30-40 HP difference. I think the programmer is a great unit because of what it can do from a diagnostic standpoint. I would suggest getting an EZ box and using the SC programmer with it. Good luck. LE
I've got an EZ, and I'm looking at 275's or the programmer for my next mod. The programmer looks good because I'm running 33x12.5's and it will adjust for tire size. How much more smoke does the programmer put out when stacked with your Comp?
does this unit allow you to adjust the tire size to correct the speedometer ..........
does it allow me to read and reset "codes" from the computer
