Super Chips + Edge Ez
I am running a Super Chip set in the high performance mode which I toll in stacked with a Edge Ez.It seems to have endless power Has anyone else tried this ?
Same Compo
I running the superchip too. I got an EZ in the drawer. I am wondering how well they stack too.
I use the superchip to clear codes and set the tire size.
If I got to stock programing will it retain the tire size. thanks Joe.
You miss spelled a word indless, I not sure what your asking? Will the ez add more mbottom end than the Super Tuner. I had a comp on 1x2 (no wire tap) and it is said to be the same as EZ. This is more than the super tuner power.
I believe you can still set the tire size in stock mode I have nerver tied it though.I allwas toll in high performance mode because it dont downshift as much.And I have already been in to the trany and torqe converter.I like the idea of running them together because tha superchips changes the shift points.
Jvenne86
01-26-2007 11:03 PM
