Super B special, Questons???
Ok yall I've been doing my research and I think I am going to go with the Super B Special single setup. How much of a gain will I see with just the turbo change, and is there anything I need to do for the added boost?(I know I need 4 inch exhaust) you guys can see my setup now, with thew new turbo and 191 laser dv's do yall think Ill break 350??? And should I change my injectors after the turbo?? or will the DV's be enough?
The Super B Special is a 64mm charger! I have a buddy that ran one for a little while and he was not overly impressed with it, he also had a 12 valve around 500rwhp. It was built/designed for the common rail trucks which are much easier to spool!
From what i have seen it's a 64mm with a 71mm exhaust wheel and 14cm housing. The few guys that have tried around here were not happy with it. Very small on the Compressor outlet?
Igor
13
12-23-2008 01:19 PM
Diesel Dave2
16
12-20-2008 07:11 PM
lteone
02-23-2005 04:31 AM
